I'm Getting a code 8...what does it mean?
After we replaced the distributor on my 93 Accord LX, I am getting a real low idle and it cranks a lot before it fires. Yesterday, the engine light came on. I did the paperclip trick and it flashes 8 times, all short. This means a code eight. Am I correct? I researched and it seems a code 8 means a "Top Dead Center Sensor" error. What exactly does this mean and how do I fix it? Could it be that my timing is off?
Thanks
Thanks
Re: I'm Getting a code 8...what does it mean? (honda_joe)
Your Top Dead Center Sensor is bad or you unplugged it while changing your dist..
[Modified by Stew Pidasso, 12:41 PM 11/27/2002]
on your car the sensor is in the dist. It is either bad, or the wiring ir on wrong. chances are with a aftermarket dist.,you got a bad one.
ham
03-07-2007 08:26 AM
