humming noise front end of 98 accord
Old 06-05-2005, 11:02 AM
team952's Avatar
Default humming noise front end of 98 accord
hey all im getting a loud humming noise from the front end of my 98 honda accord v-6. got about 119 thousand miles on it . the noise is coming from the front passenger side .i recently changed the front axle (which was bad ) wondering if it could be the front wheel bearing ?? i dont want to go out and buy one yet. i thought i should ask first ? the noise shounds like bad tire noise , it also has new tires thanks
Old 06-05-2005, 12:00 PM
Chiovnidca's Avatar
Default Re: humming noise front end of 98 accord (team952)
Does it do it while it's sitting still?
Old 06-05-2005, 12:05 PM
team952's Avatar
Default Re: humming noise front end of 98 accord (Chiovnidca)
no it does it from about 10 miles an hour and above .. it also has a brand new tranny
Old 06-05-2005, 02:56 PM
Accord95Lxxx's Avatar
as you are driving turn the wheel, right, then left. if when you turn the wheel and the sound goes away, BINGO that is a wheel bearing, and the direction you turn the wheel will tell you which side is bad
Old 06-05-2005, 03:17 PM
team952's Avatar
Default Re: (Accord95Lxxx)
thanks i'll try that .... any other suggestions out there ??
Old 06-05-2005, 04:01 PM
team952's Avatar
Default Re: (team952)
well i tried turning the wheel to the left and right but i couldnt really tell if the noise went away ... i hava a correction on the speed it takes to hear the noise i first said it was 10 mph it's more like 30mph
Old 06-06-2005, 02:27 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team952 &raquo;</TD></TR><TR><TD CLASS="quote"> any other suggestions out there ?? </TD></TR></TABLE>
Check the tires. Are they chopped?
Old 06-06-2005, 05:49 AM
deserthonda's Avatar
rotate tires and see if it goes away or changes to rear if so you got tire problem
Old 06-06-2005, 10:27 AM
team952's Avatar
Default Re: (deserthonda)
tires have about 150 miles on them
Old 06-06-2005, 01:33 PM
does not matter the miles you are diagnosing a problem so need to eliminate components from being the cause rotate tires and
drive car if noise still there than you know for sure you dont have to wonder about tires it is the easiest and cheapest thing to do ;-) it is free oh make sure they are properly inflated
Old 06-06-2005, 02:38 PM
H2290's Avatar
First off check that inflation. Check pressure and make sure it's good. Is it possible you got some tires that just have a bit more road noise than you are used to?
Old 06-07-2005, 03:31 PM
team952's Avatar
Default Re: (H2290)
thanks i'll try that first ...
Old 06-07-2005, 03:33 PM
team952's Avatar
yeah it could be possible with the tire noise but i didn'y notice it when they were first installed i'll check them for proper pressure and rotate them i'll keep you guys updated thanks
DannyGo
10-18-2014 09:42 PM
edu-dba@hotmail
08-21-2013 01:25 AM
shane2121
01-19-2013 12:31 PM
tunes12
12
08-28-2007 04:54 PM
juicedricer
03-06-2003 05:39 PM
Quick Reply: humming noise front end of 98 accord
