offset with 225 tires?
Old 01-17-2002, 09:41 AM
New User
jdmbike's Avatar
Default offset with 225 tires?
What kind of offset would be requred for a 15x7 rim on a 94 accord running 225/50's?
Thanks
Old 01-17-2002, 09:48 AM
New User
urbanlegend21's Avatar
Default Re: offset with 225 tires? (jdmbike)
none with Kosei k1's
Old 01-17-2002, 10:27 AM
New User
jdmbike's Avatar
Default Re: offset with 225 tires? (urbanlegend21)
I think the offset's avaliable for the k1's are 38 & 45.
Old 01-17-2002, 10:30 AM
New User
its 45, i think 40 will be too close
Old 01-17-2002, 12:24 PM
New User
jdmbike's Avatar
is that the setup you're using right now? i noticed you asked the same question a while back.
Old 01-17-2002, 12:26 PM
New User
well I have the K1's with 205/50/15 but we were able to fit my buddies same K1's with 225/50/15 on my car with plenty of clearance
Old 01-17-2002, 01:37 PM
New User
jdmbike's Avatar
how did they feel?
i run 205/50-16's right now, but i want to auto-x with the 15's and maybe just keep them on all the time and sell the 16's.
Old 01-17-2002, 02:06 PM
CD8
CD8's Avatar
urbanlegand: what suspension set up are you currently running. also, whats the wheel gap like with the 50 series?
Old 01-18-2002, 03:18 AM
New User
i haven't run with them yet, the tires were Victoracers V700 so I couldn't take them on the street that day but the tire size will give you a larger contact patch on the pavement which is always a good thing
15" wheels and tires are a good thing becuase it will shorten your gearing and help low end accelration a little bit, which is good for autocross
Truechoice Stage II: Ground Control Coilovers/Eibach springs -300 front 350 rear
Koni Yellow damper adjustable shocks
Suspension Techniques Rear Sway bar
DC Sports front Strut bar, upper
wheel gap is actually not that bad, but my concern with wheel gap is not based on looks. I actually raised my car up a half inch because I was starting to drive hard enough on the track to rub in high G corners
Old 01-18-2002, 07:15 AM
New User
jdmbike's Avatar
cool, thanks for all the info. a pic would be great too, if you have any.
later
Old 01-18-2002, 07:25 AM
New User
i will get one this weekend
Old 01-18-2002, 07:27 AM
New User
Boughetto's Avatar
what about some RH m5 17x7 4x114.3 with a 40mm offset? 95 accord
Old 01-18-2002, 08:03 AM
CD8
CD8's Avatar
damn ive heard nothing but good things about the true-choice product. hmmm, i wont be able to do that. im just going to end up buying GC's. i already have koni yellows, so i just need the good springs.
im not concerned with looks either. i am building my car strictly for auto-X.
Old 01-21-2002, 12:52 PM
New User
jdmbike's Avatar
Default Re: offset with 225 tires? (exaccord)
How does the true-choice product differ from ordering directly from ground control? Are they the same stuff? Reason i'm asking is that I have a set of konis on stock springs right now and am looking to buy some coil overs soon.
urbanlegend21: what kind of spring rates are you using?, if you don't mind me asking.
Old 01-21-2002, 01:02 PM
New User
no problem
300 front 350 rear
if you get much higher than that you need revalved shocks to handle the rates
the only difference is the most popular and well known truechoice setup includes the Koni shocks/struts
truechoice does offer setups without getting shocks, you can buy alomost anything you want from them
postman
04-07-2009 06:55 AM
x4thGenCafe
01-17-2009 12:05 PM
nikolai.
07-02-2007 03:45 AM
kshgl87
12-12-2006 09:32 PM
B-B-K
11
08-02-2004 06:29 PM
Quick Reply: offset with 225 tires?
