How to replace power door lock actuator? 96 accord
Old 05-29-2010, 05:29 AM
No Big Whoop
Spaceballsthelunchbox's Avatar
Default How to replace power door lock actuator? 96 accord
I did a search but no luck.
My 96 accord started making a very loud buzzing noise when I lock the driver side door. Only to lock, unlock works fine. I think the solenoid is bad, or does someone here know of a trick to fix this?
Thanks!
Old 05-29-2010, 08:53 PM
gianinline's Avatar
Default Re: How to replace power door lock actuator? 96 accord
It's the rubber inside of the actuator. You're not going to find a replacement part (rubber) at the dealer or any auto store, honda only sells the actuator assembly.
You need to remove you actuator, open it up, and either fix the rubber in a way that it's nice and steady there, or you try your luck going to a junk yard to search for one car that maybe had a "good" actuator.
I'll be going to perform this job on my car this week once again, there's a fellow member who has done a DIY for this, you just need to find it.
Old 06-02-2010, 03:21 PM
raja slams mods 247's Avatar
where is this diy? this door noise is driving me nuts
Old 06-02-2010, 03:50 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/94-97-accord-d-s-lock-actuator-microswitch-repair-reset-2465699/
pellegrino
11-09-2008 06:44 PM
Shutweld
10-22-2008 10:20 AM
mac_24_seven
11-07-2005 07:48 AM
WhiteOnRice
07-17-2005 10:02 AM
Automag928
10-29-2002 02:38 PM
Quick Reply: How to replace power door lock actuator? 96 accord
