How can you tell if your rims are leaking air??
Old 02-18-2005, 08:08 PM
'00Accordster's Avatar
Default How can you tell if your rims are leaking air??
I replaced two tires on my 17s, one had a bulge and was leaking, while the other was leaking (or so i thought). I bought the new tires and one of the wheels is still leaking air!! At this point im suspecting the rim itself. Any thoughts??
Old 02-18-2005, 08:22 PM
Slamaccord's Avatar
Default Re: How can you tell if your rims are leaking air?? ('00Accordster)
put them in water and look for bubbles
Old 02-18-2005, 08:53 PM
Default Re: How can you tell if your rims are leaking air?? (Slamaccord)
did that, no bubbles
Old 02-19-2005, 06:08 AM
Turbowa's Avatar
Spray soapy water around the bead and valve stem and look very close for bubbles. If there is even a small leak you should fne it this way.
Old 02-19-2005, 07:27 AM
TxTuner
Guest
Posts: n/a
Default Re: How can you tell if your rims are leaking air?? (Turbowa)
I didn't know RIMS leaked guess you learn something new everyday
Old 02-19-2005, 08:00 AM
NBPcivic07's Avatar
Default Re: How can you tell if your rims are leaking air?? (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know RIMS leaked guess you learn something new everyday </TD></TR></TABLE> im with u lol
Old 02-19-2005, 09:58 AM
jagged4698's Avatar
Default Re: How can you tell if your rims are leaking air?? (crableg03)
Is is possible that the rim has any damage to it? Has it ever been bent or anything like that. If it has that may affect the seal on the bead? Other then that try soapy water.... thats usally the best way....
Old 02-19-2005, 11:41 AM
philadd's Avatar
Multi-piece rims that are not welded together can leak from the rubber seals between pieces. I've seen it with a set of 3-piece Racing Harts a few years back.
Old 02-19-2005, 12:20 PM
TxTuner
Guest
Posts: n/a
Default Re: How can you tell if your rims are leaking air?? (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">
Multi-piece rims that are not welded together can leak from the rubber seals between pieces. I've seen it with a set of 3-piece Racing Harts a few years back.</TD></TR></TABLE>
Again,
Old 02-19-2005, 12:26 PM
.bagged's Avatar
Think about it. Go look on the tires on your car. They say tubeless.
Now picture a hole in a wheel from a rock or something. The air that is compressed in the tire is going to escape out of that hole.
Old 02-19-2005, 12:32 PM
TxTuner
Guest
Posts: n/a
Default Re: How can you tell if your rims are leaking air?? (bagged93accord)
Bagged, I'm not arguing, I honestly learned something today. Makes sense just never thought of it
Old 02-19-2005, 12:37 PM
philadd's Avatar
Sorry man, I thought you were giving the to the thread creator.
Old 02-19-2005, 12:38 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Bagged, I'm not arguing, I honestly learned something today. Makes sense just never thought of it </TD></TR></TABLE>
Ah.
Old 02-19-2005, 12:45 PM
TxTuner
Guest
Posts: n/a
It's ok, misunderstandings happen. And drink a for me while your at it, training and can't have alcohol till the 6th.
Old 02-19-2005, 12:52 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">It's ok, misunderstandings happen. And drink a for me while your at it, training and can't have alcohol till the 6th. </TD></TR></TABLE>
Thats ok im trashed at work off of robitussin. haha!
:robo:
Old 02-19-2005, 01:02 PM
TxTuner
Guest
Posts: n/a
Robotrips are the ****
Disclaimer: By the statement above I in no way endorse or promote the use of any type of drug. And kid's remember...
Old 02-19-2005, 07:17 PM
briq4's Avatar
Check the valve stem itself, perhaps it's leaking.
Old 02-20-2005, 06:44 AM
Pn8ballrPhoenix's Avatar
it's most likely just a bad seal, or else you have a bent rim. Take the tire somewhere and have it taken off the rim and put back on.
Old 02-20-2005, 06:49 AM
the spare wheel on my sc had a hairline crack and leaked all the air out of the tire.
Old 02-20-2005, 07:56 AM
RUBZERK's Avatar
Default Re: How can you tell if your rims are leaking air?? ("Hites")
Maybe you have a bad valve stem. It happend to mine.
Not all valve stems are made the same.
Old 02-20-2005, 08:40 AM
devilpuppy's Avatar
Default Re: How can you tell if your rims are leaking air?? (RUBZERK)
yea...my 96 exr is having similar problems....its a mystery that nobody can figure out
my car is dropped on B&G springs and tokico adjustables....and my front 2 tires always lost air, i had to pump them up every week. Then one day i put my front tires in the back...and move the back ones up, now the 2 tires in the front have the same damn problem (which used to be the tires in teh back!)
Everybody looks at me weird when I tell them my situation....then I asked them if i could put a tube inside....but they said no, its dangerous
Old 02-20-2005, 09:29 AM
darwinizm's Avatar
Default Re: How can you tell if your rims are leaking air?? (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">yea...my 96 exr is having similar problems....its a mystery that nobody can figure out
Everybody looks at me weird when I tell them my situation....then I asked them if i could put a tube inside....but they said no, its dangerous </TD></TR></TABLE>
now thats jus plain cooky
Old 02-21-2005, 06:39 AM
snyderman5's Avatar
you probably have little tire gremlins that only like to take air out your front tires
just kidding that does sound weird though
Old 02-21-2005, 08:03 AM
TxTuner
Guest
Posts: n/a
Default Re: How can you tell if your rims are leaking air?? (snyderman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snyderman5 &raquo;</TD></TR><TR><TD CLASS="quote">you probably have little tire gremlins that only like to take air out your front tires
just kidding that does sound weird though</TD></TR></TABLE>
Tire gremlins are no laughing matter
Old 02-21-2005, 03:10 PM
SearchBeforeUPost!'s Avatar
how low is the drop? Do you have camber problems? What size rim?
Quick Reply: How can you tell if your rims are leaking air??
