Having trouble re-setting "maintenance required" light
Old 02-01-2006, 11:27 AM
vettman's Avatar
Default Having trouble re-setting "maintenance required" light
Local tire store did 30K maintenance, oil change, etc. Now the "maintenance required light" won't reset using procedure outlined in the owner's manual. Vehicle is a 2001 Accord LX withe 4 cylinder engine. Using the specified procedure, light will go out but then comes back on immediately. Any suggestions/recommendations, etc. would be appreciated.
Old 02-01-2006, 11:43 AM
iam7head's Avatar
Default Re: Having trouble re-setting "maintenance required" light (vettman)
try harder, make sure the timing is exact.
Old 02-01-2006, 03:39 PM
In a Junkyard near you.
Ross 2.0's Avatar
1. Push and hold the trip reset button
2. turn the ignition to on while holding the button still untill the light goes off.
Old 02-13-2006, 02:40 PM
Chester Rumble's Avatar
Default Re: (MooGoCow3)
Will this work for an Integra too?
Old 02-13-2006, 03:25 PM
RnEpmc's Avatar
why does the mantience required light come on?
Old 02-13-2006, 03:33 PM
BLKFLSH's Avatar
Default Re: Having trouble re-setting "maintenance required" light (RnEpmc)
It is set to come on at a predetermined mileage interval. 6-7,000 miles (more or less). It is only a reminder, to remind you to do the required maintenance on your car.
Old 02-13-2006, 04:27 PM
Default Re: Having trouble re-setting "maintenance required" light (BLKFLSH)
I found my answer as well... Search > me
Old 02-14-2006, 08:21 AM
I'm a Jackass
CB5F22A1's Avatar
Default Re: Having trouble re-setting "maintenance required" light (Chester Rumble)
so how do you reset it on a 92 accord?????
Old 02-14-2006, 06:35 PM
98accrd's Avatar
Default Re: Having trouble re-setting "maintenance required" light (CB5F22A1)
Push the recessed button in the gauge cluster with your key.
clewis3
03-22-2010 05:16 AM
thefirstgen
01-27-2010 05:12 AM
khoalizzle
10-05-2008 04:06 PM
justpassin
09-15-2006 12:59 PM
edger8cer
07-21-2005 06:03 AM
Quick Reply: Having trouble re-setting "maintenance required" light
