H22 swap for a 91
H22 swap for a 91
Does any one know anything about this swap like can i use the motor mounts from my f22. is it an easy swap or do i have to move a lot of stuff around etc...
Re: (91H22Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91H22Accord »</TD></TR><TR><TD CLASS="quote">what do you mean?</TD></TR></TABLE>
bump means bumping it back up to the top so people will see it, as for the swap, stock axles/int shaft/mounts/linkage will work, u will have to mod the exhaust and wire harness and ps lines and fuel lines, for more details search
Re: (twistedbydezign)
http://www.osakajdmmotors.com/introhonda.htm
check this place out......you get the engine, tranny, wiring harness, ecu....pretty much everything you can buy the shiftlinkage and axles
i HAS questions ?
Re: (smooth95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooth95 »</TD></TR><TR><TD CLASS="quote">Its pretty simple same motor mounts</TD></TR></TABLE>
The F and H series engines and transmissions are interchangable as well, aren't they?
slo_hatch
03-31-2008 04:27 PM
