1990 Accord CB7 F22B1 ENGINE HAS FUEL AND SPARK BUT WILL NOT START. HELP!!!!!!!!!!
Old 11-12-2010, 10:25 PM
H23import's Avatar
Icon2 1990 Accord CB7 F22B1 ENGINE HAS FUEL AND SPARK BUT WILL NOT START. HELP!!!!!!!!!!
I HAVE AN 95 MOTOR IN A CB7 90 ACCORD THAT WILL NOT START i replaced distributor spark, spark plugs, main relay check all the fuses but will would not start the Engine has fuel and spark but will not start Does anyone know what this could be? SOME PPL SAY I NEED TO CHANGE THE WIRE HARNESS DO ANYBODY HAVE A WIRE Harness Diagram FOR A 90 OR A 95 ACCORD ? plzzz txt me or pm plzz need help asap 347-440-5737 anybody PLZZZ
H23import's Avatar
Default Re: 1990 Accord CB7 F22B1 ENGINE HAS FUEL AND SPARK BUT WILL NOT START. HELP!!!!!!!!!
HELP
Old 11-12-2010, 11:21 PM
H23import's Avatar
anybody
Old 11-13-2010, 06:15 AM
GhostAccord's Avatar
What ECU are you using?
If you do actually have both fuel and fire I would say your timing could be an issue. Is your check engine light on? Realistically, without knowing exactly what you have done to swap the F22B1 (VTEC) into your Non VTEC chassis. It's harder to pinpoint what the actual problem might be.
Peter Lopez
11-06-2014 06:14 PM
Joe Njoroge
08-25-2014 06:27 AM
kcollings
01-29-2013 02:59 AM
Boostedyota
06-14-2009 05:18 PM
YodajdmEK4
12-27-2006 02:05 PM
Quick Reply: 1990 Accord CB7 F22B1 ENGINE HAS FUEL AND SPARK BUT WILL NOT START. HELP!!!!!!!!!!
