F22B2 NoN Vtec Distributor work on F22B1 Vtec?? Injectors?
I am pondering on doing a swap,
will a F22B2 Sohc NoN Vtec Distributor bolt up and work fine on a F22B1 Sohc Vtec Motor?
Both are OBD1
Also the injector size/cc for the F22B2 Sohc NoN Vtec same as the F22B1 Sohc Vtec?
If I use the F22B2 NoN Vtec Distributor will the ECU throw any codes for the F22B1 Sohc Vtec motor and ECU not recognizing the Crank Sensor or is it all fine and registers through the distributor?
Both are OBD1
Re: F22B2 NoN Vtec Distributor work on F22B1 Vtec?? Injectors?
Both are OBD1
Both are OBD1
F22B2 external coil distributor
F22B1 internal coil distributor
So you would ether have to convert your wire harness to use an external coil or convert the F22B2 distributor to use an internal coil
[QUOTE=GhostAccord;37329232]What swap are you pondering? Just the distributor swap? If so don't bother it's not worth the hastle.
QUOTE]
Thanks much appreciated, very helpful! Thinking of throwing a running B1 into EF, But possibly using a B2 Vtec Head have laying around. N maybe a level2 bisi cam.
QUOTE]
Cool You may need some sort of mount modifications. I think there are a few F swaps into EF's around. I'm sure you'll be able to find out what mounts to use. I'm not familiar with the F to Civic swap..... FYI the B1 is VTEC & the B2 is Non VTEC
vtec25
11-07-2007 03:55 PM
FOMULA91
03-12-2005 05:54 AM
Art701
08-21-2004 07:39 PM
