f22 flywheel/pressure plate torque specs
Old 05-13-2007, 10:18 AM
aznej2's Avatar
Default f22 floywheel/pressure plate torque specs
Hey guys done a quick search and continuing to search but cant seem to find the torque specs on and f22 for the flywheel to crankshaft bolts and need the pressure plate specs as well thanks in advance
Old 05-13-2007, 10:35 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: f22 flywheel/pressure plate torque specs (aznej2)
flywheel to crankshaft torque spec = 75.9 lbs-ft
pressure plate to flywheel torque spec = 19 lbs-ft
When installing both of those, be sure to first tighten the bolts finger tight and then begin to torque the bolts down in a crisscross pattern in several steps.
Old 10-04-2014, 01:12 PM
jupaol30's Avatar
Mucho thanks bro!
Old 10-04-2014, 01:35 PM
masospaghetti's Avatar
Haynes manual also recommends using a threadlocking compound on these bolts, which seems like a good idea.
aznej2
05-13-2007 10:33 AM
2wheelhunter
09-12-2006 09:36 AM
b18bVtecRS
08-24-2004 03:42 PM
im_poor
05-07-2003 09:07 AM
Quick Reply: f22 flywheel/pressure plate torque specs
