1995 honda accord slightly overheating HELP PLEASE
Old 05-23-2011, 02:46 PM
Janet1995's Avatar
Post 1995 honda accord slightly overheating HELP PLEASE
Over heating this is what I have done so far. New Therm and gasget , New Timimng Belt, New Water Pump. Flushed raditor and bled it. Put antifreez in raditor and resivor.
All fuse are working and relays are good. Both fans work. I have checked for leaks and have not found any.
One thing I have noticed is when I first got this car about a year ago when ever I would shut off the car the fan would always turn on. Now that I have an over heating problem it doesn't turn on when car is off. But it does turn on when the needle is on the half way mark. but not always both fans most of the time it's just the radiator fan. Why has this change? I also have looked at the radiator what I can see and it looks like its as gaps someone said its corotuion. I also have filled up the resivor and check it whenin 10mins and its empty and I look under the car and no antifreez on ground.
So what should I do change radiator or just the cap.
Janet1995 is offline
Old 05-23-2011, 02:59 PM
Jmb106jr's Avatar
Default Re: 1995 honda accord slightly overheating HELP PLEASE
You might want to look for head gasket problem. Need to do a pressure test on the cooling system.Check out this thread https://honda-tech.com/forums/honda-accord-1990-2002-2/suspect-leaking-head-gasket-2932137/ Good luck to you.
Jmb106jr is offline
Old 05-23-2011, 03:01 PM
He knows where you live!
TheMuffinMan's Avatar
You already posted this thread............what happened to replying to that one?
TheMuffinMan is offline
Old 05-23-2011, 05:41 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
headgasket
ahobbs is offline
shawn474
07-14-2014 12:04 PM
1mugencrx
01-06-2014 06:07 AM
PLZhelp33
08-31-2012 03:14 AM
Janet1995
05-27-2011 09:03 AM
B16Power
03-28-2005 11:32 PM
Quick Reply: 1995 honda accord slightly overheating HELP PLEASE
