94 EX Heater Not Getting Hot
Old 10-06-2011, 09:20 AM
4g4dcruisin's Avatar
Default 94 EX Heater Not Getting Hot
long story short:
Fan blows harder with each setting, the upper/lower level switch works as well, same with the AC.
Doesn't get hot, not sure why.
its coooold haha.
Old 10-06-2011, 09:38 AM
redbull-1's Avatar
Default Re: 94 EX Heater Not Getting Hot
Check the heater valve in the engine compartment next to the passenger side firewall to see if the cable is still attached. If it is attached, check that the valve opens and closes. Otherwise, it may be a clogged heater core or something.
Old 10-06-2011, 09:59 AM
Alright cool. The heater never worked in this car, even before the motor swap. With the core, is it accessible through the glove box opening? or do I have to remove the dash?
Old 10-06-2011, 03:00 PM
Lost Again's Avatar
To check the valve and possibly flush the core, this would be done from under the hood.
To replace the heater core is going to require some of both.
TomCurllyFry
09-10-2014 06:25 AM
client_blue
04-01-2013 08:23 AM
j spec
10-14-2005 12:02 PM
FlexW99
05-26-2004 09:32 AM
zgrimes
10-18-2001 05:36 PM
Quick Reply: 94 EX Heater Not Getting Hot
