ECU Testing
Old 09-20-2013, 04:27 PM
bfpicard's Avatar
Default ECU Testing
Is there an easy way to test the ecu unit in my 1990 Honda Accord. I'm not getting any fire from my coil. I've tested and change both the ignitor and coil but still get no fire to the coil. I need help. The car was running but missing and all this started once I pulled the distributor to check all the wires, ICM and coil. Once I re installed the distributor, I have no fire and have check everything I can think of.
Thanks
Brian
Old 09-20-2013, 05:30 PM
NZXTInerTia's Avatar
Default Re: ECU Testing
I'm fairly sure there is a CEL for a bad ECM.
Old 09-21-2013, 04:42 AM
holmesnmanny's Avatar
use this site to test your ignition system
http://techauto.awardspace.com/
you should first check for power at the distributor it should have power when the ignition is switched on...the ecu toggles the ground side
rollinswapshop
03-16-2011 07:43 PM
rollinswapshop
03-15-2011 03:11 PM
kickz
01-04-2007 06:43 AM
civicjdmb16a
10-13-2006 06:26 PM
JDubsLoPro
06-09-2006 11:26 AM
Quick Reply: ECU Testing
