question about distributor mounting gasket
Old 08-25-2015, 02:19 PM
eckertd's Avatar
Icon4 question about distributor mounting gasket
i currently have a 99 honda accord lx 2.3, i replaced the mounting gasket on my distributor 3 times do to leaking oil and it continues to do so. could anyone tell me what the problem or the issue could be?
Old 08-25-2015, 06:03 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: question about distributor mounting gasket
Where is it leaking from?
If it is leaking between the distributor and head then the seal you may be using could be incorrect.
If it is leaking oil from under the distributor cap, most likely the internal oil seal is blown.
There is a thread in the Accord FAQ at the top of the page on how to replace it.
Old 08-25-2015, 06:28 PM
eckertd's Avatar
its coming from under the distributor between the distributor and the head, ive used both seals at autozone that they have to offer for the year and model and it continues to leak oil, ive also have a new valve cover gasket thinking it could be that
Old 08-29-2015, 04:43 AM
poorman212's Avatar
Have any pic's of the dist end where it goes into the head.
Is the o-ring fitting into the groove on the dist tight.
xcoregage
12-18-2009 12:07 AM
xcoregage
12-10-2009 11:29 AM
sonson6
03-20-2007 07:56 PM
fe519
04-25-2006 02:33 PM
Quick Reply: question about distributor mounting gasket
