Questions on Canister Vent Shut Valve - how to remove
Old 10-28-2004, 05:44 AM
Sam5's Avatar
Default Questions on Canister Vent Shut Valve - how to remove
I need to replace my Canister Vent Shut Valve. I bought the part at the Honda dealer already, but when I went to remove the old one I got into trouble.
There's only 2 screws that attach it to the canister. The bottom one is pretty corroded but I think I can get it out.
The top screw is the problem. I can't even see it. How have you guys been able to get this out? Is it easier to drop the whole canister to get access to the top screw?
Any advice is appreciated.
1998 Accord LX
4 door
2.3L
Old 10-28-2004, 06:13 AM
JimBlake's Avatar
Default Re: Questions on Canister Vent Shut Valve - how to remove (Sam5)
I got mine out using an offset screwdriver. (The bent kind that you use like a wrench...)
Old 04-10-2005, 02:59 PM
jmvar's Avatar
Default Re: Questions on Canister Vent Shut Valve - how to remove (JimBlake)
Hey guys I need to do this for my sister's car. Do you guys know where this is located and how much the part costs?
Modified by jmvar at 3:07 AM 4/11/2005
Old 04-11-2005, 09:09 AM
JimBlake's Avatar
Default Re: Questions on Canister Vent Shut Valve - how to remove (jmvar)
On a '98/'99 4-door Accord the canister is roughly underneath the left-rear seat. The vent-shut valve is bolted to the outboard end of the canister.
coder47
09-22-2013 07:14 PM
accordpilot
04-12-2011 09:48 AM
honda4now
01-11-2007 08:05 AM
Josh10e
12-14-2004 04:54 PM
alexo49
11-06-2003 03:34 PM
Quick Reply: Questions on Canister Vent Shut Valve - how to remove
