Custom Short Shifter for 6th gen CG3
Old 05-15-2005, 09:39 PM
lithiumus's Avatar
Default Custom Short Shifter for 6th gen CG3
I finally put all my pictures of my DIY porjects together so I figured I'd post each project... I have a knack for picking DIY projects that somehow becomes much more difficult than I expect...
This was a service offered for a short period of time until I quickly realized that the time spend swapping the shifter assembly was not worth the fee.
Only 3 people have this on thier cars...
- LDYKLLA aka Ian Carlo
- Jammerz on torontoaccords.com
- and myslef
Original idea:
After installing my SSA adaptor I realized that all it really did was move the link position up to create more leverage to shorten the shift. I had an idea to deweld and reweld the OEM link higher up on the shift rod.
This also required that the rod be slightly adjusted 1-2 degrees to offset the bend in the OEM rod. With the help of cntrl at torontoaccords.com who did all the welding work, this turned out to be an excellent mod.
The cheap SSA's were only held on via an allen screw pressed up against the rod. Didn't give me much confidence for track or quick hard shifting use...
Short Shift Adaptor placement for reference. This was a cheap eBay adaptor I got for $40.
I used a dremel to deweld the OEM link. I did the first one and cntrl did the other 2.
Dewelded. In the later pics you'll see that cntrl buffed the rod and you can't see the original scorching from the OEM weld.
Since I had a Momo aftermarket shifter, I cut down my rod and got rid of the OEM threads
Shortened by about 1.75"
This is the piece that holds the entire shifter assembly together. It snaps into place but is not meant to be removed so it's a struggle to pop this out. Takes 15-20 mins of fighting to get it out.
Shift rod before cntrl re-welded.
Welded and buffed
The weld can withstand up to 1000lbs of pressure.
Reassembled after welding
Comparison to OEM shifter
Another side by side.
Old 05-16-2005, 05:13 AM
Monkey Fing a Coconut's Avatar
Default Re: Custom Short Shifter for 6th gen CG3 (lithiumus)
i had tried cutting the shifter and redoing the threads on my 4th gen, who knew the shifter is hollow lower down.....ended up just buying a 4bidden, but yours looks damn good for diy...
Old 05-16-2005, 09:18 AM
fw190bvi's Avatar
Default Re: Custom Short Shifter for 6th gen CG3 (twistedbydezign)
im assuming your gonna have to tap threads into the end of it.....but looks really good......
damn, honda made the 6th gen shifter a pain in the *** to work with....
Old 05-16-2005, 10:57 AM
notoriousB's Avatar
Default Re: Custom Short Shifter for 6th gen CG3 (fw190bvi)
wow, I'm glad my B&M ss adapter doesn't hold on like that crappy ebay one, I wouldn't trust that for a minute!!!
nice work on the shifter, looks like a big ol' PITA!
Old 05-16-2005, 02:58 PM
lithiumus's Avatar
Thanks for the kudos, guys!
I didn't thread it because I was staying with an aftermarket Momo which did not require the threads.
The B&M is definitely a much better adaptor design.
mherkamp
10-07-2012 08:53 AM
pandabeareg
11-20-2010 08:31 AM
AR Fab
12-07-2007 04:26 AM
My292Ludes
09-12-2006 04:19 PM
Jxi8s2k
11-05-2005 02:25 AM
Quick Reply: Custom Short Shifter for 6th gen CG3
