Could a Bad Ignition Switch Cause No Spark ?
Old 02-20-2011, 02:41 PM
TheBigCheese's Avatar
Default Could a Bad Ignition Switch Cause No Spark ?
My 98 Accord has fuel but no spark. Turns over great but won't make any spark. The ignition switch has around 200k miles on it and looks worn out on the inside. Could a Bad Ignition Switch Cause No Spark ?
Old 02-20-2011, 03:44 PM
phootbag's Avatar
Default Re: Could a Bad Ignition Switch Cause No Spark ?
Never seen it happen. I would suspect something else like a faulty ignition coil, broken timing belt, faulty sensor etc.
Old 02-21-2011, 06:55 AM
uberEFtuner's Avatar
92 Accord Lx with 100,000
It can cause no spark. I know I,m an idiot, but I hooked up my battery backwards. Which I might have caused the lumps on contacts in my ignition switch. It would only run if I kept cranking the starter. I hot wired the car, which helped me diagnose the bad ignition.
Old 02-21-2011, 07:00 AM
ME Motorsports's Avatar
There are three, main, items that will keep the engine from getting a spark. A bad ignition coil, a bad igniter and a bad distributor.
Old 02-22-2011, 06:04 PM
craddock01's Avatar
And a bad ignition switch.Its easy to test with an Ohmmeter and a manual.
Old 02-24-2011, 06:07 PM
Just a fuse. I should have figured. The ignition switch was looking pretty bad to start with though.
Old 02-24-2011, 08:00 PM
nus_dogg's Avatar
So it was a blown fuse?
Old 02-25-2011, 08:32 AM
Yup. I think my battery charger over charged the battery. Moral of the story is to spend money on a good battery charger.
Old 02-25-2011, 11:16 AM
nus_dogg's Avatar
Gotcha.
Honda knowledge
04-18-2015 08:00 PM
jacobsd1904
02-24-2011 01:18 PM
twotonecivic
04-24-2009 09:48 PM
rizzoTK
08-29-2005 02:35 PM
Quick Reply: Could a Bad Ignition Switch Cause No Spark ?
