99 f23 overheating
Old 05-19-2009, 09:35 PM
KraKimus's Avatar
Default 99 f23 overheating
so i bought this car a few weeks ago and ever since then its been overheating and i cant figure out why. i replaced the radiator thinking that was it and it wasent....i removed the thermostat thinking that would help but it didnt. i checked my oil and its fine so it cant be a blown head gasket....i'm currently working on replacing my water pump but anyone else have anymore ideas?
Old 05-20-2009, 02:30 AM
YeuEmMaiMai's Avatar
Default Re: 99 f23 overheating
if your water pump checks out, guess what? if your fans are working, you got a blown head gasket and the exhaust is leaking into the coolant.
Old 05-21-2009, 12:49 PM
Frank Allen's Avatar
you can buy a kit to check the head gasket from local auto parts or take it to a good local radiator shop and have em check it.
pay close attn to the plastic recovery tank, lots of times the engine compression will build up and overcome the radiator cap presssure and force the collant into the recovery tank tell it gets low then it over heats, i had a 93 that did that and the radiator shop put a sealant in it, never had much faith in it but it worked and it ran without over heating for 90000 miles tell i finally got rid of it, course the correct way is replace the head gasket if thats the fault. if the radiator and fans are running , and radiator is good there is nothing else i can think of to cause this
Frank Allen
Old 05-21-2009, 09:24 PM
whitewonder's Avatar
are you losing any coolant ? is the first question.
n how many miles on the car ...
you say you "removed" thermostat ?? or replaced it??
if u are losing coolant with replacing radiator , check all ur connections on the hoses u dealt with , i would take a rather close look at your upper radiator hose that goes into a STUPID PLASTIC housing. its common to leak if over heated.
if u replace water pump you have to do the timing so if that hasnt been done you should do that to. 65$ for the 2 belts online over at majestic.
94ls
05-17-2009 03:23 PM
rowo87
Honda Civic (2001 - 2005)
09-24-2007 07:07 AM
bomber19
08-05-2007 06:57 PM
bumpin_bass
12-09-2002 11:09 PM
jdmteg
09-22-2001 01:30 AM
Quick Reply: 99 f23 overheating
