Condenser fan problems..
Old 02-01-2013, 10:10 PM
monster d's Avatar
Default Condenser fan problems..
My aunt's accord's condenser fan will not turn off after the car is full shut off. It keeps on running and is draining the battery. Every time I try to search for something about the condenser fan...all that comes up is for the radiator fan.
Things I had done:
I replaced the relay in the fuze box and proved that it was good and working, also while I was in the fuze box I checked the fuze for the fan and it was not blown.
While searching around the fan I found two relays that where incased in rubber. I took the rubber off and saw that the relays where 12v..so my question is:
1. Are both of these the same or are they different
2. And would they just be called condenser fan relay's? Since the real condenser fan relay was called a radiator fan relay lol?
Old 02-02-2013, 10:29 AM
jdowen2's Avatar
Default Re: Condenser fan problems..
Raiator fan sw and/or condensor fan sw could be shorted. If relays look the same unplugged you should be able to swap them and see if that clears trouble. Might also be AC pressure sw.
Kevonn Martin
04-26-2018 08:03 AM
fatl13ert
10-22-2012 12:41 AM
jlfosternz
Honda CR-V & Element
08-14-2011 10:23 PM
ev0luti0n
07-07-2005 10:36 AM
Quick Reply: Condenser fan problems..
