BEST GAS FOR A/AN j-spec H22A
Old 02-09-2002, 12:00 AM
Hybrid90Accord's Avatar
Default BEST GAS FOR A/AN j-spec H22A
i have a 90 accord ex with a h22a w/ LSD tranny and the following mods CAI, n2 header, hayame cat back exhaust, aem pulleys, hayame cam gears,nology wires, denso plugs, 75 shot ZEX and a few more but i was wondering if i used 93 octane gas and added that NOS (racing formula) octane booster which i said to add 5-8 poin to the octane would that make a difference, and would that mess anything up engine wise, also anyone know the top speed of an h22a engine.
MUCH LOVE ALL 4TH GEN ACCORD
SHOW THE SI'S WE CAN KICK *** TOO
Old 02-09-2002, 12:31 AM
Jason kiDD's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (Hybrid90Accord)
Why would you. Just make sure you put nothing lower than 93 in the tank and if you use an injector cleaner make sure it says safe for your O2 sensor...
Old 02-09-2002, 09:08 AM
LoudAccord's Avatar
I use 93 octane with Shogun octane booster. you can get the octane booster from pepboys. I think honda japan says to use 98 octane.
Old 02-09-2002, 10:05 AM
Nick M's Avatar
In japan they do have higher octane gasolines, and ive heard the number 98 before too. Running on 93 or 94 is probably fine. Adding octane boost wouldnt hurt but buying that all that time might get expensive. The top speed of an h22 is limited by the 5th gear, it hit the rev limiter in 5th at about 140-142.
Old 02-09-2002, 10:52 AM
LoudAccord's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (HondaSport)
I get octane booster all the time. it is 4 bux, and I can tell the difference... especially in 3rd gear.
Old 02-10-2002, 04:29 PM
New User
anotheraznguy's Avatar
i hit speed limiter at 113 mph
how u hitting it at 140?
Old 02-10-2002, 05:43 PM
Nick M's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (anotheraznguy)
Im not hitting it. I was referring to people with non-JDM ecu's. Top speed is RPM limited.
Old 02-11-2002, 09:07 AM
KGAccord's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (LoudAccord)
The place doing my swap suggests I run the NOS octane booster ever couple fill ups for a JDM motor.
Old 02-11-2002, 09:11 AM
Jason kiDD's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (KGAccord)
Not necessary, but if it makes you feel better then by all means.
Old 02-11-2002, 09:20 AM
New User
urbanlegend21's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (Jason kiDD)
nitro-methane, thats all you need
Old 02-11-2002, 09:48 AM
4doorH22's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (urbanlegend21)
I'll be bumping up my compression some day, but I never intend to use anything but pump gas. Octane boosters are so inconvenient. There's some dude here with a 12:1 CR CRVTEC running 93 pump gas no problem.
Old 02-11-2002, 10:10 AM
Jason kiDD's Avatar
Default Re: BEST GAS FOR A/AN j-spec H22A (4doorH22)
Exactly I have 11:1 CR and full advanced timing with no problems on Pump gas.
And that is just 92.. However I try to put some injection cleaner ever now and again or even some Sunoco 94 just for the perks..
racetowin
07-15-2006 09:29 AM
4DRmafia
09-14-2004 05:14 PM
type-t
09-04-2004 12:33 PM
JeremyL
06-13-2003 02:45 PM
deevergote
05-12-2003 06:05 AM
Quick Reply: BEST GAS FOR A/AN j-spec H22A
