check engine light 2000 Accord
Old 10-16-2010, 07:43 PM
jdowen2's Avatar
Default check engine light 2000 Accord coolant trbl
My brother has a 2000 Accord 4 cyl. His check engine light came on. He took it to AutoZone and it showed a coolant problem. We changed the thermostat thinking that was the problem. During the process we found the radiator cap had broken and we had to fish out the pellet off the bottom of the cap assembly. Not sure what cured the problem but the light has stayed out.
Old 10-17-2010, 08:06 PM
h0p3l355dork's Avatar
Default Re: check engine light 2000 Accord
Did you happen to get the actual code? That would help diagnose the problem. Also.. it seems like your problem was resolved, what question did you have?
Old 10-17-2010, 08:24 PM
Akkord2k1's Avatar
Yea, my mom's accord was supposedly repaired at her "go-to" shop and the CEL is still on. My dad thought it just needed a reset, I'm thinking other wise, I'm gonna try to see if i can rent a scanner at one of the autostores and check for myself. My mom's TCS and SRS lights have been staying on too and I feel like thats definitely a safety issue.
jdowen2: It might need a reset I guess if you already scanned it and fixed the TS. Not sure.
Old 10-20-2010, 09:23 PM
jdowen2's Avatar
My post was a heads up to anyone with a similar problem. Not a question, apologies for any confusion.
Old 10-22-2010, 11:58 AM
Akkord2k1's Avatar
^^ my mistake, i read it wrong. you said the light stayed off.
Old 10-22-2010, 12:30 PM
02 accord's Avatar
So what was the original problem? A "coolant problem" could be anything. My coolant problem was a leaking radiator cap, and changing the thermostat would not fix that. I didn't have a CEL either, just coolant on top of the radiator/fan.
kenchidi
Transmission & Drivetrain
12-22-2014 02:14 AM
executiveg
04-12-2012 01:00 AM
B16Jacques
05-13-2006 09:32 AM
litalang
11-10-2004 10:11 AM
Quick Reply: check engine light 2000 Accord
