Car shakes at red lights???
Old 02-14-2009, 10:07 PM
redline870's Avatar
Default Car shakes at red lights???
when i come to complete stop at red lights my car shakes. if i shift it into park and let off the brake then it wont do it anymore. its a 96 accord lx with a jdm f22b engine and tranny. any idea why it would do that?
Old 02-15-2009, 12:24 AM
jwicecold's Avatar
Default Re: Car shakes at red lights???
It could be a few things, most are pretty easy fixes.. Does it have a check engine light on?
One your idle could be to low and your car is struggle to staying idle so it shakes about to die..
Two your valves could need to be adjusted.. This a little more tough to do, have to read up on that.
Three your idle control valve could be functioning improperly..
Old 02-15-2009, 12:27 AM
redline870's Avatar
but it only does it when its idleing in drive, not when its in park or neutral.
Old 02-15-2009, 04:18 AM
kjmoy's Avatar
Try cleaning the IACV first. It is easy to do. Follow the following link. Honda 5th gen is almost exactly the same as Integra. It can't hurt.
http://www.team-integra.net/sections...ArticleID=1174
Old 02-15-2009, 05:22 AM
P_Adams's Avatar
You've most likely got a broken motor mount. It's usually either the front or (but most often) the rear.
What's happening is that the torque produced at idle is enough to twist the motor in the opposite direction. With a broken mount, the engine isn't restrained as it should be and can start vibrating or pressing against something it normally wouldn't.
The reason no vibration in neutral? No Torque to twist the engine.
Being a '96 Automatic, it will most likely be the rear mount. It's vacuum assisted and does this with a disturbing frequency.
P
Old 02-15-2009, 01:07 PM
redline870's Avatar
P
that was more the response i was looking for, something that makes sense. if it was the iacv then it would do it whenever it idles, not just in gear. i replaced the front mount when i did the swap. ill put the car on one of the drive-on lifts at work and have someone sit in it and shift it into gear to check the rear mount. thanks yet again P_Adams
Old 02-15-2009, 01:10 PM
CanadianEh48's Avatar
torque converter not disengaging from full lock?
Old 02-15-2009, 01:14 PM
redline870's Avatar
the car wont even shift into full lock. ive had a problem with this ever since i did the swap. at 75mph the rpms are at 3300. if the torque converter wasnt disengaging then wouldnt it accelerate/drive wierd at low speeds? the engine/tranny came out of a jdm odyssey so im wondering if this may be why im having issues with the tranny. im using the original usdm ecu with the jdm engine and tranny.
im starting to think that maybe the full lock issue, and shaking at stops in gear might be related?
Old 02-15-2009, 03:53 PM
CBL9's Avatar
Motor Mount, I had a simliar issue in my 1993 Accord. I just replaced the front one, all is fine now.
Old 02-15-2009, 05:14 PM
redline870's Avatar
front mount is brand new. ill check the back one tomorrow and let u know how it goes.
Old 02-15-2009, 06:10 PM
P_Adams's Avatar
GM had that problem with their first batch of Chevy designed TH700R4's. D**m things would stall when coming to a stop; every time.
Would act like you forgot to release the (std trans) clutch when stopping.
P
low'n slow
12-16-2013 02:52 PM
vvboy
08-26-2010 01:06 PM
spoon93
12-22-2007 08:05 AM
typeeg
07-04-2004 02:37 PM
pleiades nutz
01-02-2002 02:44 PM
Quick Reply: Car shakes at red lights???
