'01 brake change, need help...
Old 10-02-2005, 03:25 PM
justanek9's Avatar
Default '01 brake change, need help...
im trying to change the break pads on my sis' 01 accord ex front and read, im not sure how to go about it, this is my first time change brakes, need help thanks...
Old 10-02-2005, 04:16 PM
justanek9's Avatar
Default Re: '01 brake change, need help... (justanek9)
anybody know what to do?
Old 10-02-2005, 04:19 PM
justanek9's Avatar
i got the caliper off and the pads out, not sure what to do with the piston and how to push it down
Old 10-02-2005, 04:34 PM
justanek9's Avatar
please help, aim: battousaitms12
hondabum's Avatar
you should be able to push it with your hands if not go get some big *** pliers hope that helps
Old 10-02-2005, 04:37 PM
H2290's Avatar
I think the preferred tool is a c clamp but you should be able to just push it down with pliers or something.
hondabum's Avatar
or you could look at the other brake Q i will bump it to the top
Old 10-02-2005, 04:45 PM
justanek9's Avatar
Default Re: '01 brake change, need help... (hondabum4life)
thanks for bumping that to the top, i get the gist of it, i still can get that piston down, thanks again
Old 10-02-2005, 04:54 PM
hondabum's Avatar
maybe just use your hands at first to see how it comes apart. can you move it at all?
Old 10-02-2005, 04:55 PM
justanek9's Avatar
something is moving, i dont think its the piston? but if that the only thing that moves, im not sure how to get the pads in...
Old 10-02-2005, 05:10 PM
hondabum's Avatar
yeah grab the caliper and push the center ring piston thing with your thumes and the part that your holding on too should come toward you damn i wish i was better at computers i would be able to show you. damn where are all those comp. nerds when you need them
Old 10-02-2005, 05:12 PM
hondabum's Avatar
you didnt pay attention when you took them out did you it should be obvious what way they go in just try till they fit .
Old 10-02-2005, 05:21 PM
BLKFLSH's Avatar
you should have gotten some grease with your pads to put between the metal shims. You need a repair manual for the specifics but I think you have to put the grease on both sides of one shim and one side of the other. btw you may have to turn the piston clockwise while pushing it in for the rear calliper (emergency brake thing), it's hard to push in, I know, but you can do it.
Another important thing is to just take one side apart completly, so you can refer to the opposite side in case you forget how it goes back together.
Old 10-02-2005, 06:02 PM
hondabum's Avatar
Default Re: '01 brake change, need help... (BLKFLSH)
really you need grease i've never greased my ****, oops, why would you?
Old 10-02-2005, 06:05 PM
BLKFLSH's Avatar
Not between the pads and rotor, between the metal shims. If you get honda pads they come with the grease and instructions on where to put it.
Old 10-02-2005, 06:11 PM
hondabum's Avatar
uuuh of course not between the ****** brakes and the roter that would defeate the perpose of brakes, but why would you grease the shims i really dont know?
Old 10-02-2005, 06:21 PM
BLKFLSH's Avatar
It didn't say why in the directions but I think it was so the pads could move float around inside the calliper and not bind up. maybe so they wouldn't rattle. your guess is as good as mine.
Old 10-02-2005, 06:32 PM
hondabum's Avatar
hum well i have changed lots of brakes and never saw the grease ah-well its worked so far ,,,,maybe its so it goes in easer it is a pain to get the breake in the shims. thanks for the info ,,, you learn somthin new every day
Old 10-02-2005, 07:27 PM
H2290's Avatar
If we are talking about the same grease it goes between the back of the brake pad and the shim. This is to limit the squeeling you will get if the pad just moves around a bit inside the shim which it most certainly will do.
Old 10-02-2005, 08:07 PM
hondabum's Avatar
Default Re: '01 brake change, need help... (H2290)
i gess i am lucky than. crazy i just changed my brakes some halk performance pads and they didnt come with any grease, what the ****?
ksweetland
Suspension & Brakes
12
05-18-2012 03:19 AM
garrettej8
03-31-2007 10:16 PM
blkgsr03
11
03-22-2003 01:45 PM
harryg
02-13-2003 05:05 AM
KhRoNiX
12-19-2001 10:18 AM
Quick Reply: '01 brake change, need help...
