Can only shift into 2nd 4th and Reverse. Need Help!!
Old 10-09-2006, 11:34 AM
sparknblaze's Avatar
Default Can only shift into 2nd 4th and Reverse. Need Help!!
Ok I was having an issue with my car initially having to fight to get it into first and occasionally popping out. When shifting from second to third, I would move the selector to where third should be and release the clutch and it would grind as if I wasn't all the way in gear. I would try it again and it would work. Same thing with fifth. Now something is terribly wrong because I can only shift into 2nd, 4th and reverse and it's tough as I don't know what to get them out of these gears. When i push forward to try and access 1, 3, or 5, it will not go past neutral. I changed the shift selector thinking that was the issue but that did nothing. What's going on?
It moves freely from side to side in neutral. Car is a 95 with a recently swapped h22 vtec and a prelude tranny M2L5. Car worked fine for about a couple of weeks until this started happening. My mechanic friend checked the clutch fluid which was fine and the tranny fluid which was also fine.
Old 10-09-2006, 04:43 PM
HondaccordH22aJdm's Avatar
Default Re: Can only shift into 2nd 4th and Reverse. Need Help!! (sparknblaze)
try changing your shifter cable. or look where the shifter cable connects to ur trani. take it out and try to put it in gear by hand.
Old 10-09-2006, 09:32 PM
HatchSpeeD's Avatar
Wow, my buddies is having the same problem but opposite direction. I tried doing a hard shift into 2nd last night & I snapped one of the cables.
We tried replacing the cables which I believe were from a 90-93 accord & now it only goes into 1st, 3rd, & 5th, all of the forward motion gears. He has a 95 Accord with h22 swap. BUMP 4 you cuz we need to get this fixed as well.
Old 10-10-2006, 05:14 AM
Default Re: (HatchSpeeD)
I called the shop who did my swap and described the issue to them and he said the same thing about the cable. I'm going to swap it out and see if this fixes the problem. I did a little research and found that the prelude and accord shift linkages are interchangeable (somebody correct me if I'm wrong) so I'll be using one or the other. I'll keep you posted.
Old 10-10-2006, 05:09 PM
HatchSpeeD's Avatar
We swapped the cables with used 94-97 accord cables & its fine.
Old 10-31-2006, 06:38 AM
UPDATE: I swapped out the shifter cables and now it shifts perfectly. No slipping out of gear, or hard shifting into any gears. Thanks for the info.
B18c1vicrx
08-10-2009 10:05 AM
2ndgentegracer
06-14-2007 12:23 PM
MugenGTR
04-12-2006 09:09 AM
89civichatchback
13
07-09-2003 11:23 AM
boomslang
11-18-2001 12:00 AM
Quick Reply: Can only shift into 2nd 4th and Reverse. Need Help!!
