Cam gear removal
Old 12-05-2008, 07:20 AM
kornerk12's Avatar
Default Cam gear removal
Well I am about to replace my cam seal. How do i hold the cam while i break loose the bolt holding the cam gear onto the camshaft ? I know i could use an impact but i know that is not the proper way.
Old 12-05-2008, 07:31 AM
jweller's Avatar
I've always left the timing belt on and the plugs in. engine compression has always been enough to hold it to break the bolt free. If the timing belt is off, then hold the cam gear still with a strap wrench.
Old 12-05-2008, 07:51 AM
kornerk12's Avatar
theres no place on the camshaft where u can put an align ket or something to hold the camshaft ? I know on some h series there is
Old 12-05-2008, 11:48 AM
hondadude's Avatar
With the valve cover off, put a small pry bar between the spokes of the cam gear, brace off the head.
Po0r LiTTle CoUpe
08-03-2006 08:16 PM
4DRmafia
12-22-2005 08:45 PM
b18-c-rx
12
11-13-2004 06:11 PM
NoVtecLs
10-10-2004 11:01 PM
REDBARON
02-26-2002 11:12 AM
Quick Reply: Cam gear removal
