Blown up 91 Accord Engine - how far can one run without oil in the engine? - Honda-Tech
Old 07-21-2004, 11:42 PM   #1
giromar's Avatar
Default Blown up 91 Accord Engine - how far can one run without oil in the engine?
Driving my 91 Accord EXR station on the highway - engine blows. Luckily I had bought into an extra engine & transmission 10K miles warranty. Have the wagon towed to the nearest warranty service center. The mechanics takes a look - says there's no oil in the carter, you're not covered. Bummer...
But I just went for an oil and filter change a couple of days earlier at the local garage.
The warranty mechanics immediately suspects that the old oil was drained out but new oil was never put in the engine - it's possible since the mechanics had a couple of other items to look at on the car. So... could I have run for 200 miles over a span of three days without any oil in the engine ... until it blows up without a warning? The oil mechanic says it's impossible, I would'nt have gone 5 miles before a problem developed. Another mechanic says it's quite possible to have run 200 miles before the blow up. There is no trace of oil or oil fumes anywhere. Where could the oil have gone if it was put in the engine? Help!!!
giromar is offline   Reply With Quote
Old 07-22-2004, 01:15 AM   #2
iam7head's Avatar
Default Re: Blown up 91 Accord Engine - how far can one run without oil in the engine? (giromar)
dry fraction on the honda motor will last you a good 10 miles, once you stop the car, NO WAY IN HELL you will get it crank and start up.
should've save the link to the page, some dude is just finishing a swap, he left the car with a complete swap sitting in his garage. The only problem is that the motor have no oil, so how his sister took the car out without knowing. needless to say the newly swapped motor is toasted/seized.
iam7head is offline   Reply With Quote
Old 07-22-2004, 10:52 AM   #3
giromar's Avatar
Default Re: Blown up 91 Accord Engine - how far can one run without oil in the engine? (iam7head)
No question - the engine is fried. Needs to be swapped.
The issue of contention here is the warranty : is it possible that this engine could have run 200 miles with only drips of oil in the block? If not, then there was oil in the block but where did it go? No sign of leaks, no fumes, but yet no oil in the block!!! Could the oil have evaporated without leaving trace? Humpphh...
Otherwise everything points to the garage not putting new oil in the block!!! How to prove it ?
Old 07-22-2004, 11:10 AM   #4
iam7head's Avatar
did you stop the car in anyway?
like turning it off and restarting it in your trip?
sounds like the oil change place just toasted your new motor
Old 07-22-2004, 11:16 AM   #5
biggs2.3's Avatar
Why didn't your oil dummy light come on
biggs2.3 is offline   Reply With Quote
Old 07-22-2004, 11:47 AM   #6
giromar's Avatar
Default Re: (biggs2.2)
It all happened in a second: the dummy light went on, the engine started behaving funny with a strange defunct noise. I was on the highway, I did maybe 1000 feet to park the car in a safe area, turned the engine off and that was it. Had the car towed to the closest warranty service center and that's when after a quick inspection, I was told that there was no sign of oil in the block and that the engine was obviously toasted...
The point of contention is : was there ever oil in the block after the oil change? The warranty service center believe it's impossible there could have been oil since there is no sign of it. The oil garage on the other hand claims that I couldn't have gone 200 miles before the engine toasted if there wasn't any or very little oil !!!
I'm told by a 'car dude' buddy that it's quite possible that I could have done 200 miles before it seized !
Anyways the car is now at the service center waiting for a decision on my part (swap the engine) and I have to figure who I need to go after : the oil garage or the warranty service center. I don't feel I've done anything neglectfull...
Old 07-22-2004, 12:26 PM   #7
Moderator
tech8's Avatar
Default Re: (giromar)
The fault is the oil change garage. The warranty service center does not have to cover the damage due to negligence of another party.
tech8 is offline   Reply With Quote
Old 07-22-2004, 02:14 PM   #8
biggs2.3's Avatar
Default Re: (tech8)
your drain plug probably wasn't tightened down all the way and as you were driving it loosened up, it fell out, and then say goodbye to your oil.
Old 07-22-2004, 02:22 PM   #9
matix's Avatar
You better get a new motor out of the oil change place. If you have the reciepts im sure you can prove its their fault.Sorry to hear this.
matix is offline   Reply With Quote
Old 07-22-2004, 06:37 PM   #10
jweller's Avatar
Quote:
this sounds like the most likely scenario.
if you really had no oil in it, you would have gotten a oil light on the dash before you made it out of the parking lot of the quick-lube place.
hope you know a lawyer, you're going to need one. good luck getting one cent out of either place
jweller is offline   Reply With Quote
Old 07-22-2004, 06:46 PM   #11
fw190bvi's Avatar
Default Re: (jweller)
ovbiously the oil leaked out......so the drain plug had to not be on tight enough......otherewise theyre be signs of leakage.......is the drain plug in place/tightened down?
fw190bvi is offline   Reply With Quote
Light, white smoke from engine bay. Most probable cause? k3ntegra Acura Integra 1 09-21-2014 06:25 PM
What Typed of Oil? Answered. vtek9 Acura Integra 8 06-16-2011 12:33 AM
96 Civic engine blew aowpsycho Honda Civic / Del Sol (1992 - 2000) 14 10-21-2009 03:39 AM
Air comes out of the oil cap, when engine runs.. :( carisma45 Honda Accord (1990 - 2002) 34 08-19-2009 12:38 PM
JDM GSR B18C1 COMPLETE W/WIRING HARNESS, SKUNK2 INTAKE! fozjared For Sale 1 01-28-2006 03:39 AM
Tags
2004, 2006, 91, 97, accord, change, engine, honda, long, motor, oil, ran, run, running, seize
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
