Best OEM replacement struts to buy?
Old 07-21-2004, 11:19 PM
kkspeed's Avatar
Default Best OEM replacement struts to buy?
I own a 93 Accord SE with 93,000 miles and am looking for feedback on the best replacement struts to buy? KYB GR-2? Tokico (blue)?
Old 07-21-2004, 11:32 PM
iam7head's Avatar
Default Re: Best OEM replacement struts to buy? (kkspeed)
gr-2 agx
Old 07-22-2004, 07:49 AM
phoenixitc's Avatar
Koni Reds?
Old 07-22-2004, 08:03 AM
pyrojeff's Avatar
You can get a set of GR-2's for about $180. That's what I have right now, and they have worked fine for the past year that I've had my pro-kits on.
Old 07-22-2004, 08:08 AM
propwdialogue's Avatar
Default Re: Best OEM replacement struts to buy? (pyrojeff)
well ive put about 6000 miles on my gabriels (the OE replacement from autozone) and they have been doing just fine so if you want a cheaper alternative, i think you should be fine with these
Old 07-22-2004, 08:11 AM
pyrojeff's Avatar
Default Re: Best OEM replacement struts to buy? (propwdialogue)
How much did those cost?
Old 07-22-2004, 08:57 AM
i dont remember the exact numbers but it was something like 90 for the rears and 200 for the fronts...
Old 07-22-2004, 09:25 AM
iakona's Avatar
buy mine! they only have 1000 miles on them.
Old 07-22-2004, 09:40 AM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">if you want a cheaper alternative, i think you should be fine with these</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">something like 90 for the rears and 200 for the fronts...</TD></TR></TABLE>
Uh, $290 is not cheaper then $180.
I had GR-2s on mine before I went to AGX. I got them for $160 and I liked them...I mean as far as OEM replacements go
Old 07-22-2004, 09:47 AM
2+2=5's Avatar
Default Re: Best OEM replacement struts to buy? (JDMAccord2nr)
Dont get gabriel if you plan to have the car for a long time
Old 07-22-2004, 03:44 PM
kkspeed's Avatar
Are the KYB GR-2's the same or slightly stiffer than stock struts?
I bought GR-2's for my 90 Nissan 2WD Truck and tyhey sucked! The compression was very soft; just like a worn out shock. I replaced them with Garbiel Gas which were stiffer.
I just scared that GR-2's will be too soft for my Accord. I'm keeping it stock, but would like s slightly stiffer ride for better handling.
Old 07-22-2004, 03:46 PM
Farts in the shower
The_Todd's Avatar
Jsut got my AGX's for 175 shipped
Old 07-22-2004, 04:00 PM
jwogen1's Avatar
Default Re: Best OEM replacement struts to buy? (VRDrvr)
i have gr2s with eibach sportlines and its a great ride--im pleased so far
Old 07-22-2004, 07:01 PM
pyrojeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Jsut got my AGX's for 175 shipped
What! Where? How?
HTDragazn
Honda Civic (2001 - 2005)
10-05-2010 09:09 AM
ombl4
06-30-2007 03:49 AM
weak_tec
09-23-2005 04:01 PM
bottlefed13
Suspension & Brakes
07-31-2005 08:56 AM
01SSAP1
12-17-2004 06:37 PM
Quick Reply: Best OEM replacement struts to buy?
