1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!!
Old 01-15-2008, 05:47 PM
vg7z's Avatar
Default 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!!
Ok so my beater broke, the timing belt snapped but I got that replaced. I did a compression test and 180 180 180 90. Im pretty sure cylinder 4 has 2 bent valves. Being my cheap beater, how much life do you think is left before something bad happens?
Old 01-15-2008, 08:52 PM
YeuEmMaiMai's Avatar
Default Re: 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!! (vg7z)
it's gonna die quick unless you pull the head off and inspect it, you will have more problems than a bent valve if you keep driving it
Old 01-15-2008, 10:17 PM
hondaccord's Avatar
Default Re: 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!! (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">it's gonna die quick unless you pull the head off and inspect it, you will have more problems than a bent valve if you keep driving it</TD></TR></TABLE>
i don't know I have seen people get around for half a year on three out of the four cylinders firing. I do agree though you should fix the prob, even if its just getting a junk yard head, and slapping that on.
Old 01-15-2008, 10:31 PM
Default Re: 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!! (hondaccord)
if a valve on the intake is not sealing, you can get backfire and that will tear up stuff in your intake
5timehondaowner
10-27-2016 06:36 AM
PURPLERANGER
08-09-2014 05:43 AM
JDMBoosted
12-21-2010 01:40 PM
BoostedB20A
01-04-2004 09:12 AM
Shannons52
07-14-2003 07:25 PM
Quick Reply: 1991 Accord, 220K miles, timing belt snapped, bent valves, dont feel like fixing!!
