automatic wont shift past 3000rpm
Old 11-08-2006, 03:10 PM
v.i.gsr's Avatar
Default automatic wont shift past 3000rpm
I have a buddy with a 95 accord, and his car wont shift past 3000 rpm while driving(it acts as if it has a 2step on it) but it can be reved to redline when in neutral or park.
what can cause this.
as far as I know it is throwing a code for the o2 sensor.
I'm just tring to help a friend out.
the car is an automatic.
Old 11-08-2006, 08:57 PM
EvenStar's Avatar
Default Re: automatic wont shift past 3000rpm (v.i.gsr)
what are the gears? starting from P (park)?
Old 11-09-2006, 12:47 AM
YeuEmMaiMai's Avatar
won't shift or won't rev past 3K?
Old 11-09-2006, 04:20 AM
v.i.gsr's Avatar
Default Re: automatic wont shift past 3000rpm (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">won't shift or won't rev past 3K?
when accelerating and it reaches 3000 rpm, it acts as if its hitting a rev limiter or a 2step.
To get it to shift, you have to back off of the throttle and when rpms drop to about 2500 then it shifts.
Old 11-09-2006, 07:42 PM
Skeeter7424's Avatar
you need a transmission...one of the shift solonoids is going bad.
...skeeter...
Old 11-09-2006, 07:54 PM
hondadude's Avatar
If the CEL is on the computer runs in a default mode; fix the problem and it should rev out just fine again.
Old 11-10-2006, 11:01 AM
philadd's Avatar
Default Re: automatic wont shift past 3000rpm (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skeeter7424 &raquo;</TD></TR><TR><TD CLASS="quote">you need a transmission...one of the shift solonoids is going bad.
...skeeter...</TD></TR></TABLE>
I completely disagree with this. For one, the car seems to be driving with a lowered rev-limiter, which is probably the result of the CEL. Secondly, if a shift solenoid was going bad, you could just... *pause* ...replace the shift solenoid. An entire transmission would not be needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">If the CEL is on the computer runs in a default mode; fix the problem and it should rev out just fine again.</TD></TR></TABLE>
Follow this man's advice...
Old 11-10-2006, 03:19 PM
Jigoku Z's Avatar
Does the D4 or S light on? chances are the AT ecu is bad
Old 11-11-2006, 08:47 AM
v.i.gsr's Avatar
Default Re: (Jigoku Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jigoku Z &raquo;</TD></TR><TR><TD CLASS="quote">Does the D4 or S light on? chances are the AT ecu is bad</TD></TR></TABLE>
I have a feeling the ecu might be bad, but we just wanted to clear up the any codes (cel).
ACTION JACTION
11-07-2008 09:37 PM
dc2_916
05-17-2008 06:56 AM
Hondaz_Son02
25
10-15-2007 02:12 PM
Austin
09-05-2002 12:16 PM
EL-Teg98
01-07-2002 05:18 AM
Quick Reply: automatic wont shift past 3000rpm
