ANYONE KNOW HOW TO REMOVE HEADLIGHTS ON 94 ACCORD EX
Just curious if anyone knows how to properly remove headlights on a 94 accord ex so I can replace the bulb on the little side orange light? Also incase I get new headlights?
i think its better you get a helms manual before doing this:
1-open hood
2-remove corner lights (1 screw)
3-remove front bumper
4-remove headlights
just general steps.
1-open hood
4-remove headlights
just general steps.
H-T Order of Merit
Re: ANYONE KNOW HOW TO REMOVE HEADLIGHTS ON 94 ACCORD EX (vtec26)
There is a search feature and an Accord FAQ sticky for a reason
here's a hint, look in the Exterior section of the Accord FAQ
ate my pixel
1 Post
Re: (TheMuffinMan)
Excuse me, but the four posts before streetaccord were all about replacing the bulbs in the turn signals. If they were referring to removing the headlights, then they could have at least said BUMPER HAS TO COME OFF (to remove headlights) that would have taken a whole extra five seconds of their life to type. Don't be an ***,
common sense > you
common sense > you
To take the corners out theres a screw close to the fender in the front, unscrew and slide the light foward, if you pull it straight up, the bracket the screw goes in will break. To take the headlights out, word of advice, dont mess with the piece at the top of the light with the long bolt, there are little screws next to it that you can undo to take the light out, youll have to take the bumper off to take the lights out, youll have to take the bolts out of the light to get it to move as much as you can so you can take the plastic screws out of the bumper that are underneth the headlight. Then once you have the bumper off it should be easier to see the bolts underneth the light to take it out.
He knows where you live!
OP:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Just curious if anyone knows how to properly remove headlights on a 94 accord ex so I can replace the bulb on the little side orange light? Also incase I get new headlights? </TD></TR></TABLE>
AhhNickk
11-09-2009 04:15 PM
DaMenaCe
01-31-2009 02:16 PM
distronic
05-20-2007 12:34 PM
