Acura 3.2TL wheels on 99 accord?
Will the 3.2TL wheels fit on a 4dr 99 accord?
Does anyone have a good pic of the 3.2TL wheels I can see?
I'm looking for a factory-ish alloy, and found a set of these cheap.
What is the accord bolt pattern and a typical offset?
Thanks
Matt
Thanks
Matt
Re: Acura 3.2TL wheels on 99 accord? (GSRMatt)
they will fit on your car so long as you have the V6 accord. They will not (repeat will NOT) fit on the I4
Re: Acura 3.2TL wheels on 99 accord? (CmptchAV6)
Is the 4cyl 4x114.3? What is a typical offset? What is the 5-bolt pattern on the 6cyl?
I dont know the offset for sure but I think it is 43 for the V6 and the lug pattern for the 6 is 5X114.3 and yes the lug pattern for the 4 cylinder is 4X114.3
[Modified by CmptchAV6, 12:42 AM 5/21/2002]
offset on the 6.5" wide v6 rims is 55 mm
offset on the 5.5" wide accord rims is 45mm (i think)
i'm not sure what the 6" wide 98-02 4cyl accord offset is...probably around 50 mm
my bad 5 and 6 next to each other on the keyboard, im gonna die now.
only the v6 have 5 lugs like the TL 3.2. happy now. anyone woulda known that was sposed to be v6.
as for wheels, correct offset is 40 for 6 inch wide(16 inch), 42 for 7 inch wide(17 inch) and 45 for 8 inch wide(18 inch) that is to have the wheels perfectly in line with fender and slight tuck at far drop
[Modified by Shaggs2Dope, 7:37 AM 5/21/2002]
Re: Acura 3.2TL wheels on 99 accord? (Shaggs2Dope)
actually a V5 engine was one of the roumored engines for the S2000 before it came out or had the name s2000. Yes that is right a V5 not an inline 5. I am totally confused how honda would have pulled that motor off but I guess there was no hope for them doing it because it never appeared. Plus alot of dumb people call honda I4's V4's and honda has made a I5 that appeared on a couple of cars.
Re: Acura 3.2TL wheels on 99 accord? (01GSR)
i was listing diameter sizes commonly associated with the offset and width. most 7 inch wide wheels for accord are 17, 7.5-8 inch wide are found on 18s. not rocket science
as wheels get bigger, they get wider, to compensate for wider rim you need a lil more offest each time you get a size larger. otherwise the wheels will stick out. wanna be a stickler about anything else.
as for 5 cyl, they are just tryin to be coo like volvo
Well the honda 5 cylinder is a relitivly old engine and was found on the vigor first and then the TL. I dont know how long volvo has had theirs but Audi seems to have a pritty nice inline 5. That is the engine they used to make that 900hp VW golf
03AccordLX4cyl
11
12-20-2010 06:14 PM
mk3veedubjetta
02-14-2005 05:07 PM
fangtl
09-25-2003 12:44 PM
