ABS light - honda accord 93 EX automatic
Old 04-23-2006, 10:44 AM
jojo69's Avatar
Default ABS light - honda accord 93 EX automatic
As soon as i take off with my car, the ABS light goes on.
Any idea how to find the bad brake sensor?
Old 04-23-2006, 04:05 PM
ujhonda's Avatar
Default Re: ABS light - honda accord 93 EX automatic (jojo69)
Easiest way to find out what’s wrong, you’ll need a Honda PGM tester or OBDII with ABS DTC enabled code reader
Else you will have to remove the wiring connector from ABS module then measure the voltage, but it’ll not let you read or clear the codes.
Again if you want remove your wheels and check the ABS sensor for correct gap or something blocking it.
ABS is not easy to fix without code reader and good knowledge of electrical, yes someone will say all you have to do is replace the sensor, but which one?
Here some more to check:
ABS modulator Unit
Pulsers
Inlet / outlet solenoids
Fail-Safe Relay
Low ignition voltage
High ignition voltage
Different diameter tire
Now don’t ask me how to check them without tools
Old 04-23-2006, 04:29 PM
jojo69's Avatar
Default Re: ABS light - honda accord 93 EX automatic (ujhonda)
Does an OBDII with ABC DTC enabled code reader would work on a 93 accord?
Thank you
Old 04-23-2006, 04:33 PM
BLKFLSH's Avatar
Do you know where the service check connector is?
Old 04-23-2006, 04:35 PM
ujhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojo69 &raquo;</TD></TR><TR><TD CLASS="quote">Does an OBDII with ABC DTC enabled code reader would work on a 93 accord?
Thank you</TD></TR></TABLE>
oops, sorry dude I don't know your 93 got what OBD ? may be some pro can help here. but Honda PGM tester sure will do. take her to a shop ask them to read it.
Old 04-23-2006, 04:45 PM
ujhonda's Avatar
Ok here we go http://www.tomorrowstechnician.com/tt/tt100410.htm
Old 04-24-2006, 07:07 AM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojo69 &raquo;</TD></TR><TR><TD CLASS="quote">As soon as i take off with my car, the ABS light goes on.
you need to read the code before you jump to conclusions on a bad brake sensor,
under rt side of dash, below glove box,by the kick panel. there is a 2 wires blue connector, it might be wrapped with blue tape, jump the wires together , put the key on and read the flashes on the instrument cluster, and post them here
dcarey
12-11-2012 12:18 PM
frostykue
10-28-2010 09:05 AM
sneakerfern
02-20-2007 04:37 PM
Accord2k-Hybrid
10-27-2005 09:41 AM
TWINTURBO
07-05-2005 11:06 AM
Quick Reply: ABS light - honda accord 93 EX automatic
