Car shakes when accelarate...
Old 06-23-2007, 04:27 PM
russianswty's Avatar
Default Car shakes when accelarate...
Ok so my car only shakes when I accelarate now. I figured since it doesnt do that when the car is rolling but when I accelarate and the more aggresevly I accelarate the more it shakes.
So I thought it was my wheel bearings since one was making a funny noise when I would spin the wheel from the outside you could hear it. But it still does the same thing. So I have no idea.
Old 06-23-2007, 07:46 PM
CD5 Jeebies!'s Avatar
Location: Free bullets if you find me sucka, Washington
Default Re: Car shakes when accelarate... (russianswty)
your axels are going to ****...imo same thing happened to me.
Old 06-23-2007, 09:24 PM
fastazzf22's Avatar
Default Re: Car shakes when accelarate... (I got the CD5 Jeebies!)
x2. Or some unbalanced tires. Sounds more like the cv joints
Old 06-24-2007, 09:24 AM
PSwagon's Avatar
I've got the same problem on my 95 wagon. I think in't from the inner CV joint.
Old 06-25-2007, 12:53 AM
b20acura's Avatar
Default Re: (PSwagon)
sounds like your motor mounts. axles would shake or make noise if you are turning.
Old 06-25-2007, 06:27 PM
Default Re: (b20acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your motor mounts. axles would shake or make noise if you are turning.</TD></TR></TABLE>
??? mkay I don't know how you would get motor mounts from that.......I have had almost the exact same thing happen to me and it turned out to be an axel....putting a load on a axle going out would create agressive "vibrations" as the car moves under axxeleration but not at a roll.....but I could be wrong...but int this case I think not.....Axles ftw......done
Old 06-25-2007, 06:32 PM
Damon Reeves's Avatar
It could be either your axles, shocks, or you need new tires?
Old 06-25-2007, 10:30 PM
b20acura's Avatar
Default Re: (I got the CD5 Jeebies!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">
??? mkay I don't know how you would get motor mounts from that.......I have had almost the exact same thing happen to me and it turned out to be an axel....putting a load on a axle going out would create agressive "vibrations" as the car moves under axxeleration but not at a roll.....but I could be wrong...but int this case I think not.....Axles ftw......done </TD></TR></TABLE>
well maybe i'm wrong. but i've been selling auto parts for 4 years, and when mechanics come in to to buy motor mounts, its mostly because the car is having a lot of vibration and noise.
Old 07-04-2007, 10:15 AM
well maybe i'm wrong. but i've been selling auto parts for 4 years, and when mechanics come in to to buy motor mounts, its mostly because the car is having a lot of vibration and noise.</TD></TR></TABLE>
at an idle or under a load????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russianswty &raquo;</TD></TR><TR><TD CLASS="quote">Ok so my car only shakes when I accelarate now. I figured since it doesnt do that when the car is rolling but when I accelarate and the more aggresevly I accelarate the more it shakes.
I just fail to find motor mounts a issue with the discription this guy gave.....at any event go to the HT meet in Issaguah on the 14th........ill be der and take a look
Old 07-04-2007, 11:37 AM
b20acura's Avatar
not sure i've never asked.
Old 07-04-2007, 10:53 PM
It only shakes when your fastly accelarating, or under a load it seems. But not always. Maybe it is the mounts, I should take a look at those mounts, that could be a possibly.
Old 07-04-2007, 11:52 PM
dleccord's Avatar
why fuss over something that could be inspected visually.
Old 07-05-2007, 06:32 PM
Fern413's Avatar
Default Re: (dleccord)
Same thing has happend to me...it looks like you need to have your wheels balanced
Old 07-06-2007, 10:33 AM
lunarone's Avatar
Default Re: (russianswty)
I had the same situation when I first bought my accord last year. It was the axles wearing out. If I was accelerating, even at an already high speed, I could feel the axles vibrating the car. I changed them out and I haven't looked back since.
sedorbrian
02-01-2012 01:53 AM
KhmerdudeSiR
12
11-13-2008 06:23 PM
ekferio
05-15-2007 07:03 PM
RomoGuy
08-22-2005 05:11 PM
MeanGreenEG9
12-16-2002 07:20 AM
Quick Reply: Car shakes when accelarate...
