99 accord p1739 p0700 p1167 check engine codes help plz!!!
Old 06-19-2010, 12:54 PM
b20forlife's Avatar
Icon2 99 accord p1739 p0700 p1167 check engine codes help plz!!!
ok so i just went to autozone to get my check engine codes ran and i got a p1167 which is the oxygen sensor. Next i got p1739 wich is transaxle concer????? what does that mean? are the axles going out? and 3rd i got p0700 automatic transmission fault. Is my transmission going out? Car seems to run fine and shift ok. How do i go about fixing these codes? My car is a 99 accord with the ulev engine automatic. car seems to take a bit to shift into 3rd but doesnt feel like it slips. please help and give me way to fix these problems. car has 161,000 miles also thanks
Old 06-21-2010, 04:41 PM
b20forlife's Avatar
Default Re: 99 accord p1739 p0700 p1167 check engine codes help plz!!!
anyone?
Old 06-21-2010, 07:54 PM
sgraham01's Avatar
6th gen trannys are known for failing prematurely. May be inevitable now. o2 sensor code is probably unrelated.
Old 06-22-2010, 01:36 AM
Technical Hero
HondaPartsHero's Avatar
DTC P0700 is generated by any detected transmission fault. So any automatic transmission problem is going to throw a P0700 and another code.
P1739:
Possible Causes
A/T 3rd pressure switch signal circuit is open
A/T 3rd pressure switch signal circuit is shorted to ground
A/T 3rd pressure switch signal circuit shorted to system power
A/T 3rd pressure switch is damaged or has failed
TCM or PCM has failed
Setting Conditions = Engine running in gear, and the PCM detected an unexpected voltage condition on the 3rd pressure switch circuit during the test.
This code sets in 1 Trip(s).
These transmissions have had a lot of mechanical problems. Honda extended the warranty on the transmission to 7 years or 100,000 miles due to problems. Refer to Honda TSB #02-062 for information.
Clear the transmission codes and see if they return. If they do then repair the O2 and work on diagnosing further the trans codes. Could be a bad TCU for the transmission.
http://techauto.awardspace.com/transmission.html
Bigskyguy
11-20-2017 03:54 PM
blackj30_a
03-30-2016 11:20 AM
Hondalove99
08-01-2014 12:35 PM
VTechYo
01-25-2014 12:16 AM
chriscar00
08-25-2013 05:46 AM
Quick Reply: 99 accord p1739 p0700 p1167 check engine codes help plz!!!
