99 Accord coolant Drain Bolt
Old 05-27-2002, 06:20 AM
Guitarman's Avatar
Default 99 Accord coolant Drain Bolt
Can anyone describe where the coolant 'Drain Bolt' is located on the block. The manual appears to be a hex head bolt (13mm). But when I remove the bolt oil comes out rather than coolant. If you know please help. Thanks
Old 05-27-2002, 10:43 AM
I didn't ask for a dime.
Johnny Gasparini's Avatar
Default Re: 99 Accord coolant Drain Bolt (Guitarman)
Loosen the drain plug on the bottom of the radiator. The coolant will drain through the splash guard. Remove the drain bolt and washer from the engine block.
Old 05-27-2002, 11:43 AM
4doorH22's Avatar
Default Re: 99 Accord coolant Drain Bolt (JSM)
If it's anything like mine, and I'm sure it is, you can't see it from under the car 'cause the intermediate shaft is in the way and the block has a little like ledge at the bottom that obsures the view of the bolt. It's to the left and up a bit from the oil filter. You just have to feel for it, then fit a socket (I use a shallow socket with ~4 inch extension) on it and pull like a M-Fer until it breaks loose.
Old 05-27-2002, 11:44 AM
4doorH22's Avatar
Oh, it's a lot bigger than 13mm. At least 17 mm and it uses a big-*** washer.
missionaryrider
01-15-2010 08:23 AM
Tokonut
03-01-2009 06:33 PM
OogalyDoogaly
Honda Motorcycles
02-04-2008 05:31 AM
91H4hatch
12-26-2006 04:51 PM
Monty
07-23-2002 03:56 AM
Quick Reply: 99 Accord coolant Drain Bolt
