a few questions regarding coil overs n tail lights
Old 09-26-2012, 09:38 AM
superfly831's Avatar
Icon6 a few questions regarding coil overs n tail lights
hello i have a 95 accord v6..
im wondering if the tail lights for the 4cyl are the same for the v6..
also im wondering if i can use coilovers that are for the 4cyl for my v6..i heard i can but im not to sure...oh can i use the lowering spring for a 4cyl for a v6?..because the coil over set is expensive..thanx
Old 09-26-2012, 12:18 PM
Default Re: a few questions regarding coil overs n tail lights
No one can help?...
Old 09-26-2012, 07:28 PM
FAK_LAF's Avatar
With regard to your second question, yes the lowering springs will physically fit in the strut. Just realize that the V6 is heavier than the F-series, which you should consider when selecting the spring rate and damper for your new setup. Yes a full coilover set is more expensive than buying just springs, but you are going to have to buy a higher rate damper anyway if you get stiffer lowering springs. Unless of course you want an underdamped = bouncy ride.
tercelrcr
Suspension & Brakes
08-28-2011 08:04 PM
Ready4lyf
Suspension & Brakes
17
04-23-2011 08:37 AM
abercrombemonkey
Suspension & Brakes
10-01-2005 08:23 AM
eg6style
08-23-2004 01:10 PM
silvraccord99
02-10-2004 10:26 PM
Quick Reply: a few questions regarding coil overs n tail lights
