98 accord ex
MM Gruppe B
Re: 98 accord ex
That is the random misfire code.
If it is during idle the plugs may be loose, worn, or other ignition issues, spark plug wires or coil(s) depending on engine.
If it is during part throttle cruise, most likely a lean misfire caused by clogged EGR passage(s) in the intake manifold.
MM Gruppe B
Re: 98 accord ex
Check the valve clearances.
Usually the exhaust are tight, if they are they may hold the valve open when hot causing low or no compression and a misfire.
soLame
01-22-2014 10:40 AM
rgg1970
09-06-2010 01:58 PM
sakarigraphics
08-24-2008 11:22 AM
