96 accord trunk bedliner removal and installation
Re: 96 accord trunk bedliner removal and installation (mikeohyeah)
Have you looked inside the trunk to see if you may be able to figure it out yourself? It's actually fairly easy to do. 10-15 minutes tops.
There are 3 plug type fasteners (look like a big plastic button) holding in each side molding. Just pull them out with a pair of pliers or pry them out with a flat tip screw driver. There is only 1 screw type fastener at the back holding down the spare tire cover. Remove that with a flat head screw driver. That's it for the carpet molding/bed liner in the trunk.
latoilette
01-09-2006 10:23 AM
Nizzy
02-24-2004 08:39 AM
Nizzy
02-22-2004 01:27 PM
