95' Honda Accord- Turn Signals Dont Work!!!!
Old 01-26-2009, 07:27 AM
bigben408's Avatar
Icon3 95' Honda Accord- Turn Signals Dont Work!!!!
I have a 95' honda accord LX 5speed and just recently my turn signals stopped working. CAN ANYONE HELP ME OUT???
you can send me any e-mail, at benjamin.perez07@live.com
Old 01-26-2009, 07:41 AM
mark2583's Avatar
Default Re: 95' Honda Accord- Turn Signals Dont Work!!!!
if all 4 of them stopped working at once then that sounds like a possible fuse issue.
Old 01-26-2009, 07:54 AM
redbull-1's Avatar
Does your hazards work? If not, it can be the hazard switch on the dash.
Or it may be the turn signal relay in your underdash fuse/relay box. You might have to remove the kick panel to get to the relay area on the fuse box (the first relay, left side on the fuse box).
Old 01-26-2009, 08:08 AM
bigben408's Avatar
yea my hazard lights flash, just not my turn signals
Old 01-26-2009, 08:10 AM
redbull-1's Avatar
Then check the turn signal relay.
Old 01-26-2009, 08:17 AM
bigben408's Avatar
where is that located???
Old 01-26-2009, 08:19 AM
antbo's Avatar
i had a similar problem with an EF i had, except it was the headlights. it could just be the metal that touches each other to create the circuit that makes the light turn on, it is probably dirty, so its not sending a current when touching. i opened mine up and it was all black from dust and there was no metal exposed between the two, so when they touch it wasnt metal to metal, it was just dust to dust. so it could just be something that simple.
Old 01-26-2009, 08:22 AM
redbull-1's Avatar
On your driver side bottom, inside of car, there is a fuse/relay box. If you only open the door/cover, you will only see the fuses portion. You may need to remove the kick panel to see the relays. The relay on the left side, bottom one, I believe is the turn signal relay (or what people also call the flasher).
Old 01-26-2009, 08:25 AM
bigben408's Avatar
ok thanks ill check it out right now!!!
lien
24
11-30-2021 04:10 PM
gnxpro24
02-02-2011 03:52 PM
turboah
01-02-2007 12:35 PM
tanyeung
04-07-2006 04:53 AM
cb1999nj
12-18-2005 02:26 PM
Quick Reply: 95' Honda Accord- Turn Signals Dont Work!!!!
