p1166/67 after engine wiring harness replaced
Old 01-10-2009, 02:59 PM
Keydet08's Avatar
Default p1166/67 after engine wiring harness replaced
I just replaced the engine wiring harness on my 99 accord 2.3 vtec 175k miles and the p1166 and p1167 codes have popped up. I replaced both o2 sensors 25,000 miles ago so i believe that the o2 sensors are still ok. I have rechecked all of the harness connections around the intake manifold and they are all plugged in all the way, i have also rechecked the connections to the engine computer in the passenger area. If anyone knows what to do next i would appreciate the help. Thanks...
Old 01-11-2009, 12:42 PM
Stashu915's Avatar
Default Re: p1166/67 after engine wiring harness replaced
p1166 is a heater circiut dtc. my first step would be to check the fuse(yes, there is a fuse for the heater circuit). The fuse is Fuse number 6 in the passenger side under-dash fusebox. it will be labeled LAF HEATER. try that, if that doesn't work I can try to help you diag the problem further
Old 01-11-2009, 02:36 PM
Duane_in_Japan's Avatar
Ohm the heater circuits, this will test the wires and the heater. Also make sure that the old wires match the new wires for your swap.
RMX_EF9
08-26-2010 09:29 AM
xxbvanxx
05-30-2010 06:25 PM
503_EF9
Audio / Security / Video
05-18-2007 08:50 AM
usdm.ehtu
03-17-2007 07:54 PM
B18EG6
07-04-2004 06:25 PM
Quick Reply: p1166/67 after engine wiring harness replaced
