94 Accord LX dies, and eventually re-starts
Old 01-19-2021, 04:52 PM
EnemyOf1's Avatar
Default 94 Accord LX dies, and eventually re-starts
So it’s happened to me several times. Just doesn’t seem to start, after I drove it somewhere. Typically in 10 minutes it starts again. So it stopped for 1 1/2 years almost without a single occurrence, but then my son, woo has Been driving it for that year and a half, had it for on him Sunday night. Wasn’t see a spark when I pulled the two SP wires off and used a screw driver to get it to short to ground, didn’t see either two spark at all. Got it towed this morning and the SOB started right up and sounded like it was fine. Took to the family mechanic, and, it’s back to NOT starting. New dist cap, around the 1.5 year ago mark, new fuel filter same time. Not sure why it’s being an ***, but it is. Could it be a timing belt issue? The water pump failed and it was replaced along with tensioners and timing belt about a month ago. Was fine until Sunday. No mods just a commuter for my 17 year old to and from work. Because school isn’t a thing any more.
Old 01-20-2021, 09:11 PM
EnemyOf1's Avatar
Default Re: 94 Accord LX dies, and eventually re-starts
Anybody? Not the timing belt. Since it started after sitting got over 24 hours.
Old 01-20-2021, 11:40 PM
Jeremy64's Avatar
just a hunch sounds like it doesn’t start after it has been ran??
If the issue happens after it has ran and gets no spark i would pull the dizzy cap and check for power at the ignitor and coil while cranking the engine when still hot. They could be overheating or oil soaked and shorting. Cannot really help with any more than that.
eric the car guy has a great you tube video on how to.
Old 01-24-2021, 02:29 PM
Jeremy64's Avatar
did this help or solve the issue. We here at the forum like to be updated to help others
Old 01-24-2021, 05:08 PM
99stockcivic's Avatar
I would agree it's the distributor in some manner. Perhaps a coil, but definitely happening there. Had a similiar issue but on a Civic and the distributor had to be replaced.
Old 01-27-2021, 11:26 AM
EnemyOf1's Avatar
Thank you both. Haven’t had time so I’ll see if it’s the dist in any way.
therest
03-09-2016 07:19 AM
jake171
05-24-2011 01:24 PM
f22kid
07-17-2009 09:47 AM
snoochtodanooch
45
02-18-2007 09:21 AM
-slow ej-
06-13-2004 01:41 PM
Quick Reply: 94 Accord LX dies, and eventually re-starts
