94 Accord Brakes
94 Accord Brakes
My 94 accord brake pedal goes to the floor to stop it. I have replaced the master cylinder, bench bled, installed, bled all lines until new fluid came out. Still no pedal. It will stop but nearly goes to the floor to do so. Any thoughts?
Re: 94 Accord Brakes
What trim level is the car.....or another way, what rear brake set up do you have?
IMHO, if you replaced the booster then I might worry about and push rod adjustments (to master or pedal).....how ever since you only state the mater was replaced.
Be sure the system is/has been properly purged of air.
If you have a rear drum brake set up.......when was the last time yu adjusted the rear brakes and or pulled the drum off and inspected everything and the re-adjusted the rear?
"Holmes" - you know I'm just reading this different and offering another idea.
LX. Rear drums. rears have been adjusted and look good. I bled all bleeders, going from furthest to nearest of the MC. Read that isn't the sequence. What is the sequence and/or does it matter? I bled them all till I had new fluid coming out.
accordcle
09-18-2012 08:17 PM
