93 Honda Accord Wont Start
93 Honda Accord LX
Sometimes it starts and sometimes it wont. When it wont start it will turn over, but not start. We replaced fuel filter, spark plugs, and distributor cap.
(Ignition Module about 1 1/2 ago)
I can hear the fuel pump run!
Maybe (Main Relay) ?? Yes it seems like it is hot when it gives me trouble I realize that is a sign of the relay. Hoping its not fuel pump.
Any other ideas?
Any other ideas?
Re: 93 Honda Accord Wont Start (moo32moo32)
There actually are 2 parts to the main relay, the fuel pump is only one part.
The other part of the relay enables ignition.
So it is possible to have bad solder joints on the circuit board and still have the fuel pump energizing normally.
Re: 93 Honda Accord Wont Start (Mr Yamada)
Try opening the gas cap on the gas tank to let the pressure out. Some times it builds up and won't flow properly. Happened to my friend who has the exact car, happened on real hot days aswell. Hope it works!
Re: 93 Honda Accord Wont Start (Cody Silvius)
It's you main relay. Pull it and fix it by re-soldering the joints. Theres a thread on how to fix main relay. I believe it's in the FAQ.. Total cost to you should be 10-25 dollars. What you need:
Soldering Braid: to remove solder or you can use the lil booger picker they use for babies.. That works too
Soldering Gun and you need to buy solder made for electronic components.
If it doesn't start in the sun it's the main relay. (I know you said sometimes)
HONDA ACCORD WONT START,I REPLCED MAIN RELAY,FUEL PUMPAND STAY WONT START,CAN BE ELECT.IGNITION SWITCH?BECAUSE I JUMP MAIN RELAY YELWO WIRE THEN ENGINE START BECAUSE THAT WIRE SEN POWER TO FUEL PUMP.
pullingin
10-28-2016 02:56 AM
uszcrx
24
09-09-2006 01:05 PM
1baddcivicsi
08-09-2006 09:21 AM
