Need help or car might kill me
Old 04-23-2007, 08:46 AM
SurJones's Avatar
Default Need help or car might kill me
Okay, so when I am driving, It sounds like the car is going to take off like a Airplane / Jet. (sound wise) It is coming from the right front side. I am not honda savvy tech. Please be detailed and also maybe you can me if I can fix this myself, which I can have have done some decent work on cars. The car is a 95 Accord. 4dr. LX
Old 04-23-2007, 09:31 AM
AccordSleeperZzZ's Avatar
Default Re: Need help or car might kill me (SurJones)
when does this happen? during accel., decel., braking, cruising?
Old 04-23-2007, 10:08 AM
SurJones's Avatar
Default Re: Need help or car might kill me (AccordSleeperZzZ)
during accel and cruising, louder when turning to left
Old 04-23-2007, 10:32 AM
steerh67's Avatar
jack the car up and spin the wheel, that should give you a better idea of where the noise is coming from, then maybe we can help you out a little more.
Old 04-23-2007, 11:44 AM
Tyte-S's Avatar
Bad cv joint maybe? Had the the same sound on my 6th. Not as loud as a jet, but you could definately hear it while you were driving.
Old 04-23-2007, 12:30 PM
Hammer99ex's Avatar
Default Re: Need help or car might kill me (f23a4t)
could be a wheel bearing too... jack up the wheel u think is the culprit, and grab the tire at 12 o clock and 6 oclock and do a push/pull motion. if theres movement, its ur bearing.
Old 04-23-2007, 12:42 PM
RevenantAE's Avatar
Could be a wheel bearing. Could be as simple as a dust shield rubbing.
Old 04-23-2007, 01:01 PM
Tyte-S's Avatar
Default Re: (RevenantAE)
No matter what it is you need to take care of it ASAP. Dont want that biatch flyin off at 70mph on the highway.
Old 04-23-2007, 03:08 PM
JDM_DC4_Fanatic's Avatar
Default Re: (f23a4t)
it really sounds like a wheel bearing, however, the sound will usuially change as you accelerate/brake/turn.
Old 04-24-2007, 08:19 AM
slowly slipping away's Avatar
mine was doing the same thing, turned out to be a bad ball joint so I replaced that..then found out my wheel bearing was also bad -good times!
Modified by slowly slipping away at 4:34 PM 5/6/2007
rspdron
Honda Civic (2001 - 2005)
04-19-2011 07:46 PM
S2Kstuntin
01-17-2010 01:19 PM
projektt
04-17-2009 03:56 PM
rhdekhatchie
10
02-05-2008 10:19 PM
Cru_Jones
10-29-2001 04:46 PM
Quick Reply: Need help or car might kill me
