92 Accord rocker arm assembly torque spec??
Old 01-15-2015, 09:48 PM
Tee Mack's Avatar
Icon2 92 Accord rocker arm assembly torque spec??
Thanks guys! My first post-intro post.
I've got a 92 Accord Aerodeck 2.2I EX with a F22A7 that has an oil leak in Cylinders 4 & 3 spark plug wells.
I changed the rocker cover gasket, upper s/plug seals, removed the rocker arm assembly & changed the o-rings.
Would anybody happen to know the torque specs to tighten everything back up again??
The bolts are: 12mm and 10mm (i've seen different specs: 9-16, 12-22, 11-19, it's all so confusing!?)
After that i'll adjust the valves, so I appreciate any advice, pics or threads.
Thanks guys
Old 01-16-2015, 08:52 AM
GhostAccord's Avatar
Default Re: 92 Accord rocker arm assembly torque spec??
When you say 10mm and 12mm are you referring to the socket size? I have a listing for 8mm and 6mm bolts for the F22A rocker assembly.
6mm - 9 lbf-ft
8mm - 16 lbf-ft
Old 01-16-2015, 10:13 AM
Tee Mack's Avatar
Hahaha Yeah I was... Awesome, you just cleared everything up for me.
I watched Eric The Car Guys' YouTube video and he's using 10 & 12 mm sockets, the thread are 6 & 8 mm.
You learn something new everyday.
F22 rocker arm assembly torque specs:
8mm - 16 lb-ft (12mm socket)
6mm - 9 lb-ft (10mm socket)
Thanks alot GhostAccord
Old 01-17-2015, 06:00 AM
belairbrian's Avatar
there is a specific order for torquing the bolts. generally it is 2 turns per bolt working from the center bolts out alternating sides.
I don't have a manual covering the F22 but this is the standard procedure for Honda 4 cylinders.
Old 01-17-2015, 09:37 AM
Here ya go!
dawsonmalone
02-11-2018 03:19 AM
kidwagon
09-27-2014 04:19 PM
Hunter
02-17-2011 06:31 PM
Aquafina
06-13-2004 10:42 AM
tangb2023
01-02-2004 07:02 PM
Quick Reply: 92 Accord rocker arm assembly torque spec??
