Power wire for amp in 2006 EX Accord
Old 09-03-2007, 12:00 PM
stlucky22's Avatar
Default Power wire for amp in 2006 EX Accord
I'm trying to intstall a power wire in my wife's new car and I can't find a way to route the power wire from under the hood to the inside of the car without drilling which is what I'm trying to avoid. Anyone have any suggestions? and if I do have to drill can anyone help me with a good spot because I'm not trying to mess anything up? I've done this quite a few times, but I'm just a little afraid with this one.
Thanks,
Brian
Old 09-03-2007, 12:24 PM
YeuEmMaiMai's Avatar
Default Re: Power wire for amp in 2006 EX Accord (stlucky22)
go through the firewall and run it down the side under the carpet.
Old 09-03-2007, 12:36 PM
stlucky22's Avatar
Default Re: Power wire for amp in 2006 EX Accord (YeuEmMaiMai)
Where is the safest palce for me to drill into the firewall?
Old 09-03-2007, 01:24 PM
no need to drill, use an existing hole that is already plugged by a grommet.
Old 09-03-2007, 01:43 PM
stlucky22's Avatar
What's a grommet and how do i find it?
Old 09-03-2007, 03:20 PM
shibbywhitedude's Avatar
A grommet is a round rubber "boot". Once you find it you can use pretty much anything to push it out, such as a flathead screwdriver, pull it out with pliers, etc. When I did mine, I cut the inside of the grommet out, put it around the power wire, and put it back in the firewall. Check above the brake/gas pedals. They're usually easiest to get to on the driver's side.
Old 09-03-2007, 06:01 PM
stlucky22's Avatar
Default Re: (shibbywhitedude)
I've looked all over but can't seem to find any. Are you guys sure they have them on the 2006 EX model?
EFz6er
02-04-2008 06:13 PM
seancoleshill
08-15-2006 10:02 AM
hybrid1990crx
Audio / Security / Video
14
07-14-2006 06:46 AM
TeG cRaZy
06-17-2001 07:25 PM
Quick Reply: Power wire for amp in 2006 EX Accord
