92 accord ex HELP vss sensor
New User
ok on my accord there is a countershaft speed sensor that gives power to the two middle injectors, there must be some way that the sensor gets power from the transmission but i dont know how. does anyone know how that sensor gets power?
Re: 92 accord ex HELP vss sensor
If you have a problem with the fuel injectors and it is not the injectors itself, you should be checking the injector wiring and the injector resistor. The injector resistor is located as shown in this picture.
New User
hey thanks for the help ive already checked the resistor box with an ohm meter and it all checked fine, i routed the wiring all the way from the middle injectors and they go straight to that sensor, which only has two wires going to/away from it and they go straight across the rear of the engine and to the injectors which really confuses me why honda would do it that way??
Honda didn't do it that way. Are you tracing individual wires or just the wire bundle? The injectors get their power through fuse 20, thru the injector resistors, thru the injectors, then grounding of each injector circuit it controlled by the ECM. There is no direct connection between the injectors and either of the transmission shaft speed sensors.
FacelessDrummer
01-07-2005 04:41 AM
topdrop04
04-10-2003 04:15 PM
