92 Accord, are abs and non-abs cv axles interchangable
Old 11-23-2007, 09:20 AM
tso
tso's Avatar
Default 92 Accord, are abs and non-abs cv axles interchangable
Hi all, I have a 92 accord that I am changing the cv axles on. I apparently bought abs axles but my car is not equipped with abs. Will they still work? Thanks,
Old 11-23-2007, 10:02 AM
He knows where you live!
TheMuffinMan's Avatar
no, they're different
Old 11-23-2007, 06:43 PM
Accord SiRT's Avatar
Default Re: 92 Accord, are abs and non-abs cv axles interchangable (tso)
yes the abs axles will work on the non abs model.
Old 11-23-2007, 06:51 PM
Default Re: 92 Accord, are abs and non-abs cv axles interchangable (Accord SiRT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord SiRT &raquo;</TD></TR><TR><TD CLASS="quote">yes the abs axles will work on the non abs model.</TD></TR></TABLE>
Say what?
They're different part numbers......
Unless the 90-93 is that much different than the 94-97
*edit*
Confirmed it from Majestic, they're different part numbers from the EX (w ABS) vs DX (no ABS)
EX Left Driveshaft 101263
DX Left Driveshaft 101262
It was my understanding that the teeth were not the same
Old 11-24-2007, 05:40 AM
bjaccord's Avatar
They fit just fine.
Only difference is the ABS ring gear on the cv shaft for the abs sensor. I'm running one on my car now.
Old 11-24-2007, 07:13 AM
Interesting, is it the other way around then?
Non ABS Axles will not fit on an ABS vehicle?
I know in another thread we had talked about it and whatever the OP was doing in that one they did not fit.
*edit*
on me then
Old 11-24-2007, 09:29 AM
Ronin1's Avatar
Default Re: (TheMuffinMan)
Even if the non-ABS axles fit the ABS transmission, which they probably do, you would lose the ABS function due to the lack of a sensor ring which would not be a good thing in my view.
Old 11-25-2007, 11:49 AM
bjaccord's Avatar
Ya, all the axles will physicaly work and get you down the road, but the ABS gear will be missing so it will throw an light on the dash for ABS cars.
bob441
11-11-2015 06:50 PM
OOOtony
03-04-2009 06:38 AM
204hatch
04-04-2008 09:11 AM
shortycm17
12-26-2007 03:31 PM
charjacq
03-02-2003 09:21 AM
Quick Reply: 92 Accord, are abs and non-abs cv axles interchangable
