91 honda accord fuel tank leak
Old 04-05-2006, 02:31 PM
johnnythefox's Avatar
Default 91 honda accord fuel tank leak
my accord is leaking gas from the drain plug/screw on the gas tank. i bought a new aluminum washer but it still leaks. did i install the washer incorrectly? is there one way the washer is supposed to be installed?
what made the original washer wear out in the first place? what were the accord engineers thinking in the first place to design such a corny idea like this? does anyone have a suggestion?
Old 04-05-2006, 02:45 PM
P_Adams's Avatar
Default Re: 91 honda accord fuel tank leak (johnnythefox)
I was under the impression Honda doesn't incorporate a drain for the Tank, and Honda appears to agree with me.
http://www.hondaautomotivepart...+TANK
I don't see any screws/washers called out for a drain plug.
Perhaps something a previous hack installed to avoid pulling the tank.
P
Old 04-05-2006, 03:30 PM
Default Re: 91 honda accord fuel tank leak (BLKFLSH)
i dont know the history but it is factory made. you can see it described on autozone site: https://www.autozone.com/servl...4.jsp
Old 04-05-2006, 03:38 PM
Default Re: 91 honda accord fuel tank leak (P_Adams)
i looked at the link you provided. it looks like number 49 describes a drain bolt. should i have replaced the aluminum washer with a nylon?
Old 04-05-2006, 06:22 PM
P_Adams's Avatar
You're absolutely correct. I didn't notice and frankly never had reason to use it.
I'm curious as to why the aluminum washer failed to seal....
I believe the washer can be installed in either configuration. You may be dealing with some corrosion issues on the sealing surfaces. I'd re-check the sealing surface of both the tank and bolt face flank.
P
Old 04-05-2006, 06:51 PM
BLKFLSH's Avatar
Did you use a new washer? If you didn't you would have to line it up exactly like it was before. When you install a crush washer it makes creases in it. Just like the washer on the oil pan, you need to use a new one each time.
Old 04-05-2006, 06:58 PM
In a Junkyard near you.
Ross 2.0's Avatar
If you can't make it seal with a new washer put a little honda bond around the plug and you'll be good to go
Old 04-05-2006, 07:00 PM
Ross 2.0's Avatar
By the way P take a look at the tank in your LX-i and you'll find the plug in the back on the drivers side probably covered up by undercoating.
Old 04-05-2006, 07:34 PM
P_Adams's Avatar
Default Re: (MooGoCow3)
I'm handicaped by having a Transmission Jack, I've never had to drain a tank (except when I had to have it steam cleaned) -- so I always flushed it upside down anyway.
P
Old 04-05-2006, 07:37 PM
Ross 2.0's Avatar
Dare I ask why you steam cleaned a tank???
Old 04-05-2006, 09:11 PM
when i installed the new washer i had it in one position. it leaked. then i turned it around but this time it seeped. my thinking is that you may be right. the intial install created a new form preventing a good seal. my question is what is honda bond?
Old 04-06-2006, 03:11 AM
BLKFLSH's Avatar
Default Re: (johnnythefox)
rtv sealant made by Honda. Yes, it does say Hondabond on the tube. Ask for it by name, but only at Honda dealer.
Old 04-06-2006, 04:02 AM
P_Adams's Avatar
Remove rust, crud and varnish from the inside......
P
Old 04-06-2006, 06:14 AM
accord-pro's Avatar
Follow the suggestions offered by these guys ,, also, besides a new washer, put some teflon tape on the plug threads see if that helps..
Modified by accord-pro at 7:37 AM 4/6/2006
derekk24
04-11-2017 08:34 AM
ckur1y
06-04-2006 01:23 PM
ex_techniques206
04-20-2005 02:59 PM
Batchs
09-08-2004 07:57 AM
HankYee
10-16-2001 06:12 PM
Quick Reply: 91 honda accord fuel tank leak
