91 Accord SE sporatic no start but cranks problem HELP!!!!!
Old 07-21-2005, 05:12 AM
nyjts2856's Avatar
Default 91 Accord SE sporatic no start but cranks problem HELP!!!!!
I have a 1991 Honda Accord SE. My car starts most of the time but sometimes i will go to start it and it will just crank and not start. Then about 10-15 minutes later it will start right up. Can someone help me out with what they think could be the problem. When it is cranking the tachometer does not move. Could this be a fuel pump problem??????
thanks Will
Old 07-21-2005, 05:20 AM
deserthonda's Avatar
Default Re: 91 Accord SE sporatic no start but cranks problem HELP!!!!! (nyjts2856)
do you get spark ?? do you get fuel ?? chk thing out first a little diagnastic work never hurts .......it could be a main relay
Old 07-21-2005, 05:24 AM
cctgene's Avatar
Check to see if you have spark while cranking, if you do then I would suspect that it's your main relay.
Old 07-21-2005, 05:28 AM
nyjts2856's Avatar
Default Re: 91 Accord SE sporatic no start but cranks problem HELP!!!!! (cctgene)
so you know where the main relay is located??
Old 07-21-2005, 05:34 AM
Duane_in_Japan's Avatar
Does the tach move before an actual start (while still trying to start), sometimes the tach needs a running engine if it is off scale low (it may not read 250 RPM). Tach signal comes from the ignition coil. Ignition coil is controlled by the ignitor. Is it not starting after the inside of the car has gotten hot and then you have left the window down or the door open for that 10 to 15 minutes, then after all the hot air has escapped, it starts, get a main relay, it is a serious wear and tear item. Hold the new one in your hand and then look up under the dash on the drivers side for the old one.
Duane in Japan
Old 07-21-2005, 05:36 AM
nyjts2856's Avatar
Default Re: 91 Accord SE sporatic no start but cranks problem HELP!!!!! (Duane_in_Japan)
what else could the main relay make not work?
Old 07-21-2005, 05:37 AM
nyjts2856's Avatar
and how do i keep this from happening again if this really is the problem?
Old 07-21-2005, 05:38 AM
Myroslav's Avatar
main relay is to the left side of the steering wheel. Just poke under the dashboard, you will first have to remove the cruise controle module (big metal box - 2 - 10mm screws), after you are bound to see the main relay. It might get a little tricky to remove the whole thing so you might consider replacing only internal part of it (it is hold by two plastic holders on the sides).
Geil Philip
06-18-2018 12:54 PM
HndaOwner
05-10-2014 02:17 PM
boostedh22fag
01-18-2013 12:30 AM
rated_r
11-22-2003 01:49 PM
Quick Reply: 91 Accord SE sporatic no start but cranks problem HELP!!!!!
